Car Audio 101 - The Big 3 Upgrade
2 Q's
Ive heard not to ground to suspension bolts?
and
When you did the alt, you just left the factory alt wire just hanging there? Thats not good to have a positive wire just hangin around. and you didnt say wat to do with it.
but its nice to see a vid of this to help ppl out.
Are you sure? I thought he left it connected and overlapped the new 0 gauge wire over it?
thats what you should really do, i just watched again and its just hangin there.
2 Q's
and
all factory connections should stay the same, he should have put the big 3 wire over the factory connection
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
My battery is under the back seat as well. So, you should fuse the alt. to battery + wire within 12 inches of the batt, or 12 inches of the alt? I was going to do it closer to the alt. but it looks like you did it closer to the battery in your video.
By the way, when it said "do not loose the factory nut" when you unscrewed the nut on your alt. in the video, it should say "lose" not "loose". If you want it to look a bit more professional.
To be honest, I would be concerned about a potential short occuring somewhere between the alt and the batt in the back. So, I would recommend fusing next to the alt up front AND near the batt. That way if a short occurs anywhere between the alt and batt the fuses will pop and you won't have a fire.
Thanks for the FYI. I can't spell. ;)
Mike Stiers
Product Development & Technical Support
Maxxsonics USA
MB Quart , Hifonics , Crunch & Autotek
Car, Home & Marine Audio Products
Maxxsonics YouTube Channel
2 Q's
and
I measured the resistancein this vehicle for good sources of ground just as I do in every app. I found that the stut bolt was equal to a factory ground bolt on the frame about 10 inches lower and to the left. You can see it in the vid. The front frame was actually the worst.
I removed the factory charge wire from the alt and battery. Both where taped and secured. In most apps I would recommend keeping it since it is generally integrated in the factory fusing. In this vehicle it was not. In my Neon it was and I simply added an additional 0 awg charge wire on top of it.
Mike Stiers
Maxxsonics USA
As mentioned in the vid as well as the details to the vid on youtube, you can simply overlap the new runs.
I mentioned above why this was not the case in this vehicle. More is better for sure. Just not required in this installation.
Mike Stiers
Maxxsonics USA
Very nice man.
This should help the new comers and people that want to do a big three for sure. As long as they do a search before asking... LOL :D
Also thanks for taking the time to answer some question for me about that Colossus amp..
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
Great tutorial. We need a section in SMD just for tutorials IMO that would make it easier for newer people to find. again nice job :D
Eclipse cd7000
Very nice man.
No problem. Just hope I've helped a bit.
Mike Stiers
Maxxsonics USA
  • Who's Online   0 Members, 0 Anonymous, 3008 Guests (See full list)
