kentb Posted August 21, 2009 Author Report Posted August 21, 2009 here is the vid! name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>" type="application/x-shockwave-flash" width="425" height="350"> watch in HD! New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
Nightshade Posted August 21, 2009 Report Posted August 21, 2009 Nice! It's hard to move a shirt at all and the 10's look like they're doing a good job at it. Also I watched in HD 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
kentb Posted August 21, 2009 Author Report Posted August 21, 2009 Nice! It's hard to move a shirt at all and the 10's look like they're doing a good job at it. Also I watched in HD thanks a lot! need to break this subs in should move more air as time progresses. im thinking of doing 45's on the box using resin. do you think it will help? New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
Nightshade Posted August 21, 2009 Report Posted August 21, 2009 thanks a lot! need to break this subs in should move more air as time progresses. im thinking of doing 45's on the box using resin. do you think it will help? Yeah 45's definately won't hurt as long as you don't displace a ton of airspace inside. Try and keep it to a minimum like around .2-.3 cubes at absolute most with amount of resin used. That would be about a whole gallon and I doubt that you'll use that much. A good way to figure out how much cubic feet of resin you are using is to mix it in a square tupperware container and then calculate it's volume. That's how I get my resin displacement exact in my boxes. Or if you use the whole container of resin just calculate it's volume minus the airspace inside not used since they don't come filled all the way to the top. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
LoudBimmer Posted August 21, 2009 Report Posted August 21, 2009 those 2 little sub play pretty good, and air movement is pretty impressive
superduper Posted August 21, 2009 Report Posted August 21, 2009 very nice... i will get there some day
kentb Posted August 22, 2009 Author Report Posted August 22, 2009 those 2 little sub play pretty good, and air movement is pretty impressive very nice... i will get there some day thanks brothas! it definitely hits the lows. gonna try some higher tuning soon New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
mhart Posted August 22, 2009 Report Posted August 22, 2009 that is a bad little setup you got, good job. '00 Honda Civic Si IASCA stock trunk/pickup 1 World Record 4/20 150.6/150.7dBTeam DC Team XS Power Team ISB Steve's Body Shophttp://www.dcsoundlab.com/
brewer_brewer Posted August 23, 2009 Report Posted August 23, 2009 nice. i like ssd's. they hit all notes pretty good. a cross between a RE SE and a FI BL. REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
