tumminellon Posted August 17, 2009 Report Posted August 17, 2009 I WAS WONDRING IF ANYBODY HAS ANY PICS AND INFO ON HOW TO MOUNT THE BLUE STINGER DIGITAL VOLTAGE GAUGE TermLab 148.9 @ 39hz BURP 148.8 on music
tibs Posted August 17, 2009 Report Posted August 17, 2009 mine is on the top left corner of my windshield just dont use the sticky shit it comes with it falls off. get some 3m double sided tape name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350"> Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace
tumminellon Posted August 17, 2009 Author Report Posted August 17, 2009 PICS ANYBODY??? TermLab 148.9 @ 39hz BURP 148.8 on music
Pitbullx Posted August 17, 2009 Report Posted August 17, 2009 mine is mounted to the lower part of my dash with the supplied mounting screws Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
zacht214 Posted August 17, 2009 Report Posted August 17, 2009 mine is mounted to the lower part of my dash with the supplied mounting screws can you please take caps off. and mine is on my lower right hand side of my steering wheel i also used the supplied mounting screws 2 15 RE SE 1 Audiopipe 1500d Sony HU Batcap 800 in the back Team Tex~Flex
OLDSKOOL78302 Posted August 17, 2009 Report Posted August 17, 2009 i molded my into the dash. HEAD UNIT JENSEN VM9312 4 12" KICKER COMPS 4 PUNCH 150 AMPS "0NE ON EACH SUB" 2 ALPINE 3522 ON MIDS AND HIGHS MLA MOD BIG 3 OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK 2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200" DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
