Hobby's 2004 Silverado Ex Cab
The first one i saw was mayos box at the PCA finals or meca show i forget which. But i didnt think it was resin because thatd be crazy expensive. whats the cu. ft. of that box?
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
First baffle getting put in.
The back and bottom section goes on next.
Then skip agead a little. The top baffle is attached. I ran a flush trim bit around the inside port opening to flush up the edges. Filled in all the screw holes with Duraglass then sanded and sanded and sanded.
Then after a lot of coats of poly and more sanding I had this.
All of the inside was coated with polyurethane several times and smoothed out.
haha yeah i was joking xD maybe for my truck build haha but once you get pics post em in the tdh spot xD
Will do man.
Its around 10 cubes net tuned around 34hz. All I did to Mayos box was put the stencil on it. Not sure if or what he finished it with. I thought he liked his boxes raw and neked :D
you do some beautiful work
with that type of bracing on the inside i dont know how you left the top port wall unbraced
R.I.P!
(Nov-29-2009)
92 explorer
current build
That's some good wood working there!
Ray
2012 Jeep Grand Cherokee Laredo
Kenwood DDX9702S Connected with iDatalink Maestro
Cactus Sounds PF K5 w/ 1 Sundown Audio Zv.4 "10
Cactus Sounds PF 250.4 w/ SSA Evil 6.5" Midranges & Evil 1's Tweeters
Northstar  D3100 in the rear
Its mashed up against the back wall pretty tightly. Most of whats taking the brunt of the pounding is braced :D
its going start slapping against the rear of truck and break it haha
R.I.P!
(Nov-29-2009)
92 explorer
current build
Thanks Ray.
Come down to the shop when you want to build that next box. Should be able to knock that out pretty quickly. You can take it home to make it look pretty.
I also made some alum bus bars to wire the subs. Made things a lot easier to get setup. The rear 5 subs were wired into one pair and the other 5 into the second pair. Ran the + and - from both bars to 2 pair of binding posts I purchased at Parts Express.
Heres the first pict of it with all the subs installed and the 2 Rockford T-600.2's mounted.
Sorry no picts of the wiring inside the box.
