enemyofsilence Posted August 18, 2009 Report Posted August 18, 2009 (edited) ok so i recently changed the air filter in my 03 expedition (5.4L V8) from stock to a carbon fiber based filter. and there was a plug that connected to my stock air filter and i have never seen one like this before. i have changed air filters before but this is the first time i see it (first time i changed a filter in a ford). those of you who run Ford trucks/SUV's, do you know what this plug does? Since i have it currently disconnected the "Check Engine" light has turned on. is there a way to bypass this feature? i will take a pic in a few but was wondering if someone knows what im talking about and could help a brotha out. thanks Edited August 19, 2009 by enemyofsilence Quote Team Bass-Hz
enemyofsilence Posted August 18, 2009 Author Report Posted August 18, 2009 pictars are in. ive tried googling it but i cant really find anything on it. anyone know??!?!?!? :help: here is the stock air filter. this is where the plug connects to... here is the inside of the filter. im guessing its some kind of sensor... i dont know what to do...someone please help. kthanks Quote Team Bass-Hz
ImLow78 Posted August 18, 2009 Report Posted August 18, 2009 (edited) Looks like a Mass Air Sensor and no you can not bypass that with out a Huge modification to convert your ECU to a speed Density based system. You could try and take that sensor out of the factory air box and try to graft it into the new air tube that you have the filter attached to. It could also be a Air inlet temp sensor and if thats what it is you can take it out of the factory box plug it in and zip tie it to the aftermarket filter where it can get a reading of the air temp that is going through the filter. Post a picture of the aftermarket intake system. That way we can see what kind of options you have on putting the sensor in that air tube. Shannon Edited August 18, 2009 by ImLow78 Quote 2004 Tahoe.Equipment Kenwood DNX7100 Kenwood Bluetooth adapterKenwood iPod interface cableAudiocontrol DQXSAlpine PDX 4.150Rockford Fosgate punch 40DMS Diamond Audio D363.5 (6.5" Components) Front DoorsDiamond Audio D363.5 (6.5" Components) Rear DoorsJL Audio 15w0's Subs In a 8cu. ft. Box.Monster cable XLN PRO RCA'sMonster Cable 16ga speaker wireMonster Cable 1/0,4ga power, Ground cable.I only got this Monster Cable stuff because I got it dirt cheap. (Crack Head Prices)
finkster Posted August 18, 2009 Report Posted August 18, 2009 x2, your car will run like shit without that Quote DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
AR1684 Posted August 18, 2009 Report Posted August 18, 2009 plumb a hole into the new air box for it problem solved Quote
Stephen Posted August 18, 2009 Report Posted August 18, 2009 mass air flow sensor, surprised your car runs Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
enemyofsilence Posted August 18, 2009 Author Report Posted August 18, 2009 ok well i didnt want to modify it too much so i can try to pull it out of the stock and place it next to my new filter. the reason i took this out was to make room for a new batt. and that stock filter is HUGE and takes up a lot of room. so if i understand correctly, pull it out and place it next to my new filter (zip-tie?). Quote Team Bass-Hz
ImLow78 Posted August 18, 2009 Report Posted August 18, 2009 (edited) ok well i didnt want to modify it too much so i can try to pull it out of the stock and place it next to my new filter. the reason i took this out was to make room for a new batt. and that stock filter is HUGE and takes up a lot of room. so if i understand correctly, pull it out and place it next to my new filter (zip-tie?). Not if it is a Mass Air Sensor! That will have to be placed in the air tube after the filter. (You don't want to F that thing up!) Only way you would have been able to zip tie it to the filter would have been if it was a Air Inlet Temp sensor which looking at the plug now, I don't think that is what it is. (Sorry man!) Shannon Edited August 18, 2009 by ImLow78 Quote 2004 Tahoe.Equipment Kenwood DNX7100 Kenwood Bluetooth adapterKenwood iPod interface cableAudiocontrol DQXSAlpine PDX 4.150Rockford Fosgate punch 40DMS Diamond Audio D363.5 (6.5" Components) Front DoorsDiamond Audio D363.5 (6.5" Components) Rear DoorsJL Audio 15w0's Subs In a 8cu. ft. Box.Monster cable XLN PRO RCA'sMonster Cable 16ga speaker wireMonster Cable 1/0,4ga power, Ground cable.I only got this Monster Cable stuff because I got it dirt cheap. (Crack Head Prices)
enemyofsilence Posted August 18, 2009 Author Report Posted August 18, 2009 (edited) as for the intake, it is all stock except for the filter that is shown in the pic. everything else is the same... edit: well it seems like the stock filter is gonna have to go back on...damn, i really liked that space for my extra batt. back to the drawing board to find space for my batt... Thanks all for the help!!! Edited August 18, 2009 by enemyofsilence Quote Team Bass-Hz
Derrick824 Posted August 19, 2009 Report Posted August 19, 2009 You need to install it into the new pipe. Quote
