i know they are 49h x 20h, forgot depth though.
is this with everything stock in the truck? like not taking out any panels or anything right?
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
cool. i think ima go with 2 18s instead of 4. 2 lvl5's on 6000+ rms wont be no joke. and ill save money vs the planned 4. but with that being said how large of a box should i plan on? im gonna try to get around 12 tuned to 35hz. whats the best set up for a tahoe? subs up port back? or everything back?
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
cool. exactly what i wanted. i like watching the subs jump out the box. where do you have your amps mounted? i plan to do it under the second row seat.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
so if i did a box that was 48wx20hx30l which would come down to about 12cubes or so after bracing what kinda room do you think would be left?
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
There would be very little cargo room. I went around 22-23" to get to the top of the 2nd row seat. That would put you over the window line btw.
2 18s is much easier to plan for, and once you have the equipment you can always upgrade. If you were going to move the 2nd row more than 1" I'd remove it entirely otherwise your passengers would hate you :)
Here's a pic from a while back. I don't know how accurate that is but it might help.
Edited by tejcurrent
tejcurrent
XS Power
T3
Thats a Tahoe? The Box in my Burban measures 48x48x20
(Thats with 6in left over from the box to the rear doors) and my batteries are where the 3rd row used to put their feet.... :8)
