OrenB217 Posted August 24, 2009 Report Posted August 24, 2009 So ive been hearing that if you are not too crazy about getting extremely low on songs, but getting the loudest out of your sub, you should build your box to the smallest that the sub requires (15" btl is 3 cubes i believe). For a trunk car is this true? Like my original plan is to do 3.75 cubes at 35 hz. But im not crazy about lows (even tho btl will play them no matter what tuning the box is) but i just want to get loud as fuck for 1 sub in a trunk Black 1998 Nissan Maxima1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk2nd Setup: 147.8 DB @42 HZ On Music Out The TrunkCurrent Trunk Build:153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)Team gg.
EricR Posted August 24, 2009 Report Posted August 24, 2009 that would be correct. also aero's and psp ports are more efficient thats why you see them more in spl setups. i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
OrenB217 Posted August 24, 2009 Author Report Posted August 24, 2009 that would be correct.also aero's and psp ports are more efficient thats why you see them more in spl setups. right, but idk how to do that, ill see if my friend does Black 1998 Nissan Maxima1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk2nd Setup: 147.8 DB @42 HZ On Music Out The TrunkCurrent Trunk Build:153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)Team gg.
keepinitloud Posted August 24, 2009 Report Posted August 24, 2009 I think I have talked to you before about putting one fifteen in your ride my dreadnaut 15 is in a little over 3.5 cubes and it smashes the lows no problem and is very loud its powered by a planet audio vx2200d 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
wL<3bass Posted August 24, 2009 Report Posted August 24, 2009 Also tons of port area is usually your friend.... I like between 12-16 for normal boxes and 16-20 for daily/spl Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
OrenB217 Posted August 26, 2009 Author Report Posted August 26, 2009 I think I have talked to you before about putting one fifteen in your ride my dreadnaut 15 is in a little over 3.5 cubes and it smashes the lows no problem and is very loud its powered by a planet audio vx2200d oh yea thats right, i think u posted about if it will fit in a civic, which is why i started this topic to see if smaller is better cuz it will give me a bit of insurance on space when making the box smaller. Def def man, i just wanted to make sure it wont lose dbs, but its a bonus cuz itll gain dbs and smaller boxes help yield higher output and power handling so i will probably get the most outta the wattage assuming i have good electrical. Also tons of port area is usually your friend.... I like between 12-16 for normal boxes and 16-20 for daily/spl def man, hella big port, smaller box is what im looking at Black 1998 Nissan Maxima1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk2nd Setup: 147.8 DB @42 HZ On Music Out The TrunkCurrent Trunk Build:153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)Team gg.
