It's a used cap, and i don't know what a charging card is. I'm guessing like a manual for it
no, you need a resistor to "fill" up the capacitor correctly.
and yes. you'll want to do postive wire to capacitor, then from capcitor to the amp. the do same with the grounds, but make sure to use the (-) terminal on top.
edit
when i used a capacitor, i never used a resistor. you will create a huge spark of energy the first time you connect the battery to the capacitor. i wouldnt reccomend doing it tho
Edited by J00bles
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
well you put the positve wire coming from the battery in front on the postive side of the capicator and then you run another wire from the capicator to the amplifier.then you run the ground wire into the capicator and then run a seperate wire from the ground of the capcator to the amp.and then it should power on the cap with your amp
So does this mean i need somthing else before i can install this cap?
Honda Accord 4 Door
Current System -
(2) 12'' Mtx Thunder 5500's
(1) Alpine Mrp-m1000 @4Ω
(1) Pioneer Deck Deh-3500
(1) American Legacy 1.0 Farad Capacitor
(1) Stinger Voltage Meter (Blue)
Big 3 Knu 1/0
Box 3.4^3@37hz
edit
So this will work and i should Expect a big spark?
Honda Accord 4 Door
Current System -
Big 3 Knu 1/0
Box 3.4^3@37hz
yes. it melted metal. it (more or less) pulls a ton of amps in a split second, which will cause the metal tops of the capacitor and the wire to "spark"
no you shouldnet expect a big spark unless you have a small fuse upfront
Well anyone that has given me advice on this i Thank you ALOT and J00bles glad to see someone else from Omaha on SMD.
Honda Accord 4 Door
Current System -
Big 3 Knu 1/0
Box 3.4^3@37hz
no you shouldn't expect a big spark unless you have a small fuse upfront
I have a Stinger 4gauge wiring kit, not sure what amp my fuse is. Will connecting the cap blow my fuse?
Edited by Demo402
Honda Accord 4 Door
Current System -
Big 3 Knu 1/0
Box 3.4^3@37hz
you probably wont have a big issue with that wire.
i was using an 8awg amplifier kit when i had mine installed, which will have a different effect.
and i hear ya man, not to many of us Nebraska guys on here. there are a few big systems around though
edit**
nope, it shouldnt. i used 40 amp fuses and they never blew from it. you have probably a 50-60 at a minimum with that 4awg kit
Edited by J00bles
