Hey guys. I got an Alpine Type R 2ohm dvc and a 2 channel Kenwood KAC-X20 amp. I've been trying to figure out how to wire the type r so i get a 2 ohm load to my amp. Currently i just have each voice coil wired to each channel on the amp. Please help!!!!! Or is this the right way to wire it? Also i have my gain about 3/4 max and i smell the subwoofer when i bang. The woofer is 500 rms 1500 max. My amp is 260 x 2 @ 2 ohm rms. Do i smell it only because it is brand new or do i need to turn down the gain? Will a Bass Knob cancel out the gain control on the amp if installed? PLEASE HELP!!!!! AHHHHHHHH!
According to your info, your pushing 520 RMS to a sub designed for 500 RMS and your gain is "About 3/4 max". you didn't properly set your amp.
Use this:
http://www.stevemeadedesigns.com/board/ind...ost&p=62427
To set your amp.
I'll do the math for you. Use a DMM set to AC voltage, play a test tone (I can't remember which frequency) and turn the gain up till your DMM hits 31.62 volts.
:ph34r: EDIT: play a 50Hz test tone with all settings on the HU and amp set to flat and start the gain at the minimum.
Edited by 1992Chevy
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
50 HZ teest tone usually is a good avg
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
To the OP, what HERRIE I think was trying to tell you was that maybe you should change your "TOPIC" to say something more like "Question on wiring amp" as that might appeal to more people to help you out................. not HELP!!! See what im saying?HERRIE is a good guy here, and is always very helpful, Saying what you said in your post, was out of line bro...... Take it easy here, we all just a bunch of laid back folks here! And BTW, Welcome!
Sorry man I wasnt tryin to be a prick just that the last couple of times i have tried to get help on here people have treated me shitty. Kinda was on the defensive. Sorry Im a newbie.
2000 Chevy Silverado ext cab
Kenwood Excelon X-692 Head Unit
Kenwood Excelon KAC-X20 Amp Wire to Alpine Type R 12" 2ohm
Infinity Kappa 6.5" and 3" pushed by rockfored 400.i? or something? I'll look later. Its 2 amps in 1
poor herrie took a tounge lashing :friends: be nice he means well
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Sorry guys dont mean to be an asshole for the first impression at all. Herre my bad! Anyways im not quite understanding how to properly set my amp. Any step by step directions any knows?
rockfordfosgate's web site has a woofer wiring program should tell you how to wire that beast up
big 3 1/0
  • Who's Online   1 Member, 0 Anonymous, 522 Guests (See full list)
