plumbcrazy's 2001 ford ranger build
That's no where near enough port area for that size box. Your doing right around 5sqin of port per cuft and that's just way too small an amount. I would honestly add two more 4" ports, but you'll need to be longer than what you have deep to tune them low enough to listen to. If you have 14" deep in the box the most you'll want to go with the ports is 10.75" which is .75" for the thickness of the wood and 10" inside the box so it leaves 4" from the back wall so the ports aren't choked off. You would have to figure out how to put a bend on the ports to get the length that you need, or just mount them on the side of the box and push the other side all the way against the passenger side of the truck. Anyway you look at it you don't have enough port for the box to breathe correctly and you are definately going to lose output.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Plumb I have a quick question for you. I am also working on a ranger build but mine is a 02 edge. Seeing as yours has four doors and the enclosure looked to stretch all the way across. How did you deal with those damn seat belt buckles that stick out of the rear doors?
do u not have bolt on there? im sure everycar got bolts to take the belts off..
also plumb... nice build its lookin good im curious on how the turn out is
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
