badcayne Posted August 30, 2009 Report Posted August 30, 2009 how or what do you guys use to calculate multi sided/angle boxes? reason i ask is because im having a hard time calculating the cu.ft of a box. heres the dimensions i came up with just not sure of how to calculate all the different angles any help/pointers are appreciated.
OBI Posted August 30, 2009 Report Posted August 30, 2009 For that your going to have to split the box up into sections, then add them all up.
slmd95s10 Posted August 30, 2009 Report Posted August 30, 2009 the12volt.com has a calculator for boxes like this. check it out HERE 2003 Chevy Avalanche Z66 Headunit: Pioneer AVIC-F700BT Amps: US Amps XT4000D, US Amps XT 1600.4 Front Stage: CDT Audio EF-61FG 6 1/2" components Rear: Pioneer coax's Sub Stage: RE SE15D4's
OBI Posted August 30, 2009 Report Posted August 30, 2009 Here's what I came up with. Should help. Might wanna make it a tad smaller though. But then again Idk what your going to do for bracing or how big your port is going to be.
badcayne Posted August 30, 2009 Author Report Posted August 30, 2009 .75 mdf. well based of the design OBI did. i came up with around 5.5cuft before sub,port,bracing. does that seem about right,or did i miss something?
badcayne Posted September 4, 2009 Author Report Posted September 4, 2009 .75 mdf.well based of the design OBI did. i came up with around 5.5cuft before sub,port,bracing. does that seem about right,or did i miss something? anyone?
