it seems to me u have an idea in your head that you want these things to play low.
most likely the resonant frequency of those 8's is above 40 hz. that is way to high for HT setups
now you see a good t-line is built to the specs of the subs. you can increase the length but im not sure on the conequences or benefits.
you could just build a box and tune it low and see what happens.
t-lines require a lot of info to create and you seem to have none.
just food for thought
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
x2 on the build a low-tuned box.
t-lines need quite a bit of knowledge if you want them to play correctly. the smallest screw-up can cause them to play horribly. (not using that as a scare tactic)
People use PA speakers with FS in the 40s and 50s all day for HT sub duties down to 20Hz.
I would go ahead and try out a 40Hz t-line...if it doesn't play low enough than start adding stuffing.
The enclosure should not be that hard to design if you have sketch up.
Start with a long trapezoid with the ends the throat and terminus...throat is the bigger end and terminus the smaller. Then start folding it.
Or you can just design a stepped taper which is easier
i may be wrong here but arent most HT setups tuned around 20 hz? sometimes even less?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
