So iam probably going to get a fosgate amp but there is two channels on the amp** right ?? so its only 1000 watts per channel ? can somebody explain Bd monoblock to me please... also any suggestions for a sub(s) to pair with it
Thanks
Edited by Bowser91
Pioneer MVH-P8200 Hu
Dc Lvl 4XL 15"
AudioQue 2200 sold
Knu wire 1/0 ultra fleks & Krystal Kable Rca
Stock alt
Stock battery up front
Xs S3400 in back sold
your trunk lid is going to get molested like a drunk stripper at an orgy.
Thanks
Its a Mono block as in terms of of 1
Mono=1
Stereo=2+
the amp has 2 sets of out puts (2+ and 2-)'s to make wiring DVC
There is only 1 channel though
Pioneer 500UB
1 LVL4 15" 4.3cubes tuned to 35HZ
BXi1606D
1/0
Red top in back
JBL 5 1/4's front
Infinity Kappa 6 1/2's rear
145.7 Legal on music New Audio Control
there are two outputs yes but they are wired together internally. so bassically if you have 2 2ohm speakers wired to them the amp will see a one ohm load. if you have 2 4ohm itll be 2 ohm and so forth.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
wouldn't 2 2ohm subs be .5 ohm load and 2 4ohm subs be 1 ohm ?
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
for dvc if you wired them that certain way yes but if you had svc subs then no
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
If your using 2 subs
Dual 2's parallel/parallel .5 ohm series/parallel 2 ohm and series 8 ohm
Dual 4's parallel/parallel 1 ohm series/parallel 4 ohm
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
i have heard that RF amps are really underrated? and if so buy how much?
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
the few that I had T20001bd were about 300 watts more than the specs
SMD SuperSeller VerifiedJbondoXJames Shields
I've owned two of them and @ 2 ohms they have just a little less power than my T30001 @ 2 ohms. But @ 1ohm it is way different. The T20001's have just as much power @ 2 ohm as they do @ 1 ohm
Alpine INA-W900
Rockford Fosgate Punch 200ix
Rockford Fosgate power T1500-1
Sundown SA-10 x2
Focal 6x8's front
Rockford Fosgate Power T1682 rear
Rockford Fosgate and Stinger Wiring
Powermaster D3400, S680
