Headunit Problems?!?! Needs to be solved for tom.
So i took my system out of my 95 1500 ram because im moving it all to my 98 durango.
anyways i took the deck and wiring harness out, and began to wire a different deck in. Its a JVC
i have the wire harness adapters for the stock harnesses and everything worked fine on my other deck.
So i get this JVC all wired up and deck wont turn on, it has power because it will load and eject discs but wont turn on to play anything. So i went and double check constant 12v and acc both were fine. Deck still would not turn on. Checked all fuses to do with the radio and all were good. So i took the constant 12v from the harness and directly went to the battery and still nothing. Deck works i tried it in another vehicle. Only thing i can think off is when i took my other deck and harness out i left the bare wires dangle till i got the other out and a few touched each other but no arcs/sparks happen any tips is appreciated.
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
UMMMM do 95 1500 harness work with 98 durangos also?
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
getting a new harness for the durango need to keep the one witnthe ram because my dad
still wants an aftermarket deck in it.
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
bump need to fix this for tomorrow all help in appreciated
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
Did you hookup ground? It won't be in the harness.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
Check your switched power wire (the red one) you should have 12 volts with the key on if you don't than binggo...most decks will still eject with just constant power so this is what lead me to beleave it's your switched power wire.
The Shoe Maker without shoes!
  • Who's Online   0 Members, 0 Anonymous, 881 Guests (See full list)
