michaelholey Posted September 8, 2009 Report Posted September 8, 2009 I have a pretty dumb question that I wanna get cleared up. my friend says he can power his 2 subs with a 2 channel amp down to .5 ohms without any problems. I told him otherwise, yet he still is convinced that he can do it. he thinks I can power my 1 ohm amp down to .5 ohms also. Please tell me I am right and he is wrong. Thank you!!!! Quote
Guest Posted September 8, 2009 Report Posted September 8, 2009 (edited) tell him to wire his amp down to .5 ohms stereo and see what happens Edited September 8, 2009 by Krannyman92 Quote
bennett15 Posted September 8, 2009 Report Posted September 8, 2009 not sure about the 2 channel amp but depending on your amp you could wire it down to .5 it will prob get very warm but depends what amp it is. Quote 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
CaptainzPlanetz Posted September 8, 2009 Report Posted September 8, 2009 The Mono amp may or may not be able to run at .5 ohms, also given you have good electrical to run at .5 ohms, the 2 channel amp tell him to do, and then record it and post it on here, I need a good laugh. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
michaelholey Posted September 8, 2009 Author Report Posted September 8, 2009 I was pretty sure I was right I just wanted to make sure thanks Quote
splzx3 Posted September 8, 2009 Report Posted September 8, 2009 The Mono amp may or may not be able to run at .5 ohms, also given you have good electrical to run at .5 ohms, the 2 channel amp tell him to do, and then record it and post it on here, I need a good laugh. x2 Quote ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
rawlins87 Posted September 8, 2009 Report Posted September 8, 2009 you could run .5 ohm (with a 1ohm stable amp) if there was enough box rise Quote
Boon Posted September 9, 2009 Report Posted September 9, 2009 you could run .5 ohm (with a 1ohm stable amp) if there was enough box rise Fuck. Read my post about box rise, search the subwoofer subforum for it... Quote 10.x volts fo' life!
Sampsonite Posted September 9, 2009 Report Posted September 9, 2009 you could run .5 ohm (with a 1ohm stable amp) if there was enough box rise Fuck. Read my post about box rise, search the subwoofer subforum for it... http://www.stevemeadedesigns.com/board/ind...c=46770&hl= Box rise is NOT a constant. It changes massively depending on the frequency being played, it's all about the impedance/inductance curve of the woofer + enclosure combination. Quote --Sampson 816-591-6592 www.kcrimshop.com
CaptainzPlanetz Posted September 9, 2009 Report Posted September 9, 2009 ^^^^^^^^^^^^ Which is why competitors can factor in box rise, since they only burp one frequency, the only way I would run an amp at .5 ohms is if I did research to make sure the amp could handle that low load. BTW to the OP what are the amps you are talking about?. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
