So this is the deal... Try and follow it...please please please help
I was bumpin a couple weeks ago and all of a sudden the system turns off (No sound but HU is still on and playing)
So i figured something maybe came loose where the battery and brain are...(btw fuses are good)
so somehow my dumbass clips the top of the amp with my allen wrench when im unscrewing the power so i let go and try and quickly move the wrench off the amp , sparks fly, i burn the top of the amp where the allen wrench hit. and my finger is pretty burnt from the heat of the allen wrench. after i try and move it iirc i hear something and i see smoke coming from under the false floor (this is the point where i freak the fuck out)
so i called andy over to try and help.
originally i was gunna see if it was a remote problem so i was gunna touch power and remote to see if the amps turn on... well after i burnt my shit i took the 100.4 out and kept the 3k in to see if that worked...i turned the car on and the HU wouldnt turn on.
i open the 100.4 and it looks fine? and i get everything out and nothing looks burnt.
But there was a screw that was holding my false floor down that looked like it melted and the carpet was burnt too (so im not sure if that was where the smoke came from)
i hooked up the amp again (no initial spark from the Power) i touch the power and remote and turn the car on... headunit doesnt turn on but the lights turn on on the amp.
turn the car off and turn it back on (with out pwr and rmt touching) the HU turns on then i touch the pwr and rmt and the lights on the amp turn on and the HU stays on but no sound.
i hook the 3k up to the 4g where the 100.4 was...there was an initial spark but it doesnt turn on.
voltage to everything is fine btw
is there anyway i can check the rca's with a mulimeter to make sure they work
any idea fellas i am in need of some help. i have spent soo much money on my system and i cant figure out whats wrong :( please help
check sig for system details
Edited by 99GPGTX
Currently:
2015 Evo X WW
Forgestar F14 18s --Rally Armour Mudflaps
ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers
Build:
Crescendo Mezzos x2
Crescendo 800.4, 1500.1
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Sky High Audio Wiring
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded
12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids:
Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit:
knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400
TEAM DEADLY HERTZ!!
Financial Consultant- Charles Schwab
if anything i can sent the 100.4 to get fixed but originally why would the amps be off?
we were maybething remote prob. so HU problems? i hope not but
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
ill check back on this later
any idea please post them up
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
that sucks i ve been there before with problems
if you wanna check the rca real fast get a cheap pair and just run them.
i would take the hu out check on grounds
in the past i have started fires and melted wires becuse of bad grounds
i have had problems in my car with blowing fuses and not being able to find them.
made the radio not work, ran hu owen power supply for memory and keep acc switch with key
that made it work again.
i dont really know what to tell you but a few ideas maybe
~2006 chrysler Sebring~
~2 runs of 1/0 front to back~
~1/0 wire for "big 3"~
4 spl-hx 12'' dual 2
2 dtr 1.3400
3 c&d terminologies 1000s
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
custom dave the box guys box
new stuff on the way
Team
Soundstream
Maybe your ground came out of one of the amps. Probably smoked up the RCAs and the ground traces on the headunit. Also the input circuit on the amp might have suffered depending on what sort of design it is..
You really need to break the system up and troubleshoot it item-by-item.
10.x volts fo' life!
ya i figured i would need to part it out and test...but i check the rca's and usually they would either look/smell burnt but they look fine..and the rca's on the amp too
so check grounds?
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
so check grounds?
Could well be your headunit's ground track that's gone out... amongst other things by the sound of it :(
you can check your rca's though. set you dmm to ac voltage & put the positive to one part of the rca & the negatice to the other (outer ring or post) then play a song with some beat that changes from high to low, see if the meter changes with the beat. thats what I do anyway.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
as soon as i get out of class i will try that and see what i get...
other than that will i jsut have to part out and test???
not sure how i would do that for the brain (if i have to replace that ill shit bricks)
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
oh the head unit i dont know if this will work but maybe try to grond out the hu case dont think it will make a diffrent. but if all else fails
2 dtr 1.3400
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
Team
Soundstream
  • Who's Online   0 Members, 0 Anonymous, 607 Guests (See full list)
