Fuse Holders
What do you guys with 10+ anl fuses do? Make your own holders? Or just buy some? Looking for a nice cheap alternative then spending about $15-30 per. It homemade would mdf template with 2 bolts on each side, w/washers and nuts, work?
i personally think i would do some abs if that was the case but Id rather just buy them. It will look better in my eyes and if they are on display its aesthetically pleasing. And I hate trying to dig fuses out.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I forgot but in one of the build threads someone had a 2X4 and had the fuses bolted into the wood with each side of the fuse connected with the same bolts to ring terminals of the wires.
So basically you have -------Wire/terminal---connected to bolt1/1 side of the fuse-----then bolt2 connected to the other side of the fuse/terminal of the wire after the fuse. Not so asthetically pleaseing but it works.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 1024 Guests (See full list)
