Fi Car Audio
I decided to rip the bench seat out and build a box in the middle thats goin to be about 2cuft and like 33hz. Im goin to have it runnin of rockford fosgate power 1500. ill proable run a yellow top battery and stock alt.
Im just lookin for tips, box ideas, better amp to use, or if i could get away with runnin without a extra battery.
ALSO ANYONE GOT A BL METERED
Setup:
Headunit: 7" indash screen
Sub: fi bl 12
Amp: Audioque 1200D
Box Ported tuned to 34hz
Big 3 done in 1/0 gauge
Had a Bl 12 running off ~750 watts in a 2.2 cube box with a 3 inch aero port, all put behind the seats of a 99 dodge 1500 in a custom box i made. Did a 136.8 which was the highest i ever got. Now i've got an all fiberglass box (about 2.5 cubes with a 6 inch aero tuned to 36 hz) with a IA DP 12 running off ~1500 watts hitting 140.. :) But both my boxes were behind the seats, not center console. If i really wanted to go that extreme i woulda put a 15 in the center..
I have had mine metered with the same amp, same sub, same battery (but + a Kinetik 1800)
I hit a 142.1 at around 40 htz
In fact heres a vid
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
after i get the frames build up for the bucket seats and get them bolted in im goin to do some meauring and see if i could fit a fi bl 15" but idk it will be close hope i can
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
What kind of truck is this going in? I have an 08 silverado reg cab with 3 10" treos in a console box but I am thinking about going to a Fi sub. 10" is the biggest i can do without glassing
2xSundown SA-8
Hifonics Hfi2000D
US Amps 2150
Selenium Super Tweets
KnuKonceptz wire
Its goin in a 1990 gmc truck 1500
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
  • Who's Online   1 Member, 0 Anonymous, 3049 Guests (See full list)
