EXO Needs YOU! 18" Subwoofer Enclosure Design - Ascendant Audio Mayhem
EXOcontralto
Only custom made Aero ports are harder to tune, the advantage of a custom made port is mainly you get to have a large port area with out running multiple ports, however if you do presicion ports they already have a range of tuning frequencies available, and are changed by extending or retracting the length of the port, the only thing with precision ports is you may have to run multiples to get the proper port area for the size of your box, the general rule of thumb is 12-16 square inches of port per cubic foot of your box.
With that comes the actualy ports - Where could I find correct ports for this application?
No on has yet answered if this way is the "best" way to go.
- Slotted Ports facing rear v.s. Aeroports facing upwards?
The REAL YouTube Page
●▬▬▬▬★▬▬^๑۩۩๑^▬▬★▬▬▬▬●
Head Unit - Pioneer DEH-p6000ub
Equalizer - Soon To Come
Amplifiers - (4) Soundstream TX1.2600d's
Subwoofers - (2) Soundstream XXX 18's
Enclosure - 16 Cubic Foot Wall Tuned to 38hz
Power Wire - (200ft) Tsunami 0 Gauge PRO
BIG 3 w/ 8 C&D Batteries
Team DBs (Driven By sound)
You can get AeroPorts off of Parts Express give me a sec I will get you a link.
Ha even though you posted the link before me I can still Ninja you.
http://www.parts-express.com/pe/showdetl.c...tnumber=268-354
They arent exactly cheap, but they will give you a little DB gain.
¿ǝɯɐƃ ǝɥʇ
i was stuck on slot's for a long while till i learned how much more efficient aero ports are. you can use less port area for aeros = saved space. but that doesnt really matter for you :).
you can buy them at www.partsexpress.com
http://www.parts-express.com/wizards/searc...amp;x=0&y=0
for a random box, lets say 6cuft, you can use three 6" flared ports (gives 14sqin of port area per cuft). tuning the box to 32hz would mean each port would have to be 33.8" long. 38hz would be 23" long.
Is all this true even with all this info? Only 6 cubes? - check this out
Subwoofer - Ascendant Mayhem 18
ported enclorsure - 5to8c cf
mouting depth - 10.75in
driver cutout dia. - 16.750
driver overall dia - 18.500
driver displacement - 0.26 cf
Fs - 33.7
Qms - 6.52
Qes - 0.29
Mms - 307g
Sd - 1210cm^2
Vas - 148.9l
SPL - 94.8
Bl - 17.7
Xmax - 30mm one way
RMS - 2500w
Qts - 0.28
With all that, is 6 cubes with what you explained probably the best case scenerio?
Fs - 33.7
Qms - 6.52
Qes - 0.29
Mms - 307g
Sd - 1210cm^2
Vas - 148.9l
SPL - 94.8
Bl - 17.7
Xmax - 30mm one way
RMS - 2500w
Qts - 0.28
i just threw a random box size out there but it can work yes. if you choose to bump it up a bit, lets say 7cuft. (i have no experience with that woofer so i dont know what it likes besides what AA gives)
7cuft, 32hz, three 6" aero circle ports, each would be 28.5" long
same with 40hz is 17" long each port.
38hz is 19"
35hz is ~23"
Actually it might be easier to make a slot port, as the aero ports only can extend to 17" long, so you would have to glue a PVC pipe or something in between in order to the the length you need for the tuning you want.
¿ǝɯɐƃ ǝɥʇ
for you brotha sub(s) up port back will get deff loud...
mostly in vehicles like suv's and vans get louder that way..
and for trucks subs up port up..
correct me if im wrong..
and about the slot ports those also get hella loud..
those would also work for you..
im sure pioneer saturn would hook you up with a design..
hit him up and see whats up!..hes the person i go to for box designs!! :good:
So screw the aeroports? - Slotted port will be just fine? - I need a design!!
The slot port will work fine, and will be much more cost efficient, however about your design I cant really help you with that, I am decent at designing but I would much rather you get a design from a more so experieced builder than I.
¿ǝɯɐƃ ǝɥʇ
I will design a box for you that is tuned to 34hz with 90 sq inch of port area and 6 cu ft big.
It should be ready in a few hours.
Dimensions: 30 inch wide, 29 inch long, 15 inch high.
Port: 10x9 inch port, lenght:27.61 inch long.
^^^this is close to 6cu ft (with displacement of port and driver.)
  • Who's Online   0 Members, 0 Anonymous, 3765 Guests (See full list)
