EXO Needs YOU! 18" Subwoofer Enclosure Design - Ascendant Audio Mayhem
EXOcontralto
I'm not planning on having a wall with horizontally mounted subs - I want a wall to literally separate the rear from the front - I would still have a box - just in a smaller amount airspace -
I will have a solid wall, with 2 18's tapered and fiberglassed around the edges to make it look solitary. - I want the subs to face out ports facing back - that way i'd have to have like a couple inches between then back wall and the rim of the box
Feel me>?
i got you that would be pretty cool never seen that done before
For beats Click Here
Head Unit- power acoustik 8" touchscreen
doors-RE 57 fr
sub - sundown audio e8
amp-PG v752
Yes I understand what you want. Okay just seal the back wall off at the fenders. Now for the sub are you wanting it sub up port back, or sub forward port up, or sub forward port back?
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
I'm still tossin between subs up port back, or subs forward port back
I'm not sure if I'll just use the kids plans that are in this thread, or make a single box for the 18 alone
I just want someone to come on here, and be like, I can make you the loudest box for that 18. So far that hasn't happened yet lol
THANKS FOR ALL YOUR SUPPORT EVERYBODY!
Anyone wana take up the challenge? What's the loudest box design for this subwoofer givin what you see in my caravan, and all?
The REAL YouTube Page
●▬▬▬▬★▬▬^๑۩۩๑^▬▬★▬▬▬▬●
Head Unit - Pioneer DEH-p6000ub
Equalizer - Soon To Come
Amplifiers - (4) Soundstream TX1.2600d's
Subwoofers - (2) Soundstream XXX 18's
Enclosure - 16 Cubic Foot Wall Tuned to 38hz
Power Wire - (200ft) Tsunami 0 Gauge PRO
BIG 3 w/ 8 C&D Batteries
Team DBs (Driven By sound)
for the specs you gave me off 3k your gonna want like 6 cubes net 34hz 90sq in port i cant design you somethign when you still have no idea what you wanna do for sure
Well if you have the money for a lot of wood it can be done and have someone with a TL meter to test several designs out it can be done. Without testing man honestly it's hard to say what would be best, that is something that takes time and money my friend.
J&T DESIGNS
M5
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
I want what's best for this subwoofer - that's all
- if you know what will sound the loudest with a lot of deep bass, than I trust you -
i would suggest that you use Aeroports so that you can experiment on some really low low tuning(high 20's) for massive flex on your videos and some high tuning(40+hz) when you compete so you get very good numbers(possible 150).
Aeroports? How could I have variable port tuning??? What do you mean?
Aero ports are kind of like using a PVC pipe for the port, where you can have different length pipes that you attach to the box for different tunings.
If I understand correctly, you want a divider to isolate the rear of the vehicle from the front and this is what your calling a wall, most people understand a wall as the whole box, not just this sheet of wood, thus the confusion and frustrations. You want to make this box separate from this divider, or use the divider as the back of the box?
It would look sort of like a chair from the side view with the legs and back as one piece going really high, and the seat and front not going the full height. At least that's how I've pictured it.
In that configuration I would personally consider subs up, port forward, with the port in the middle, or subs and ports up. There may be problems with those designs that Accordman or others may know from experience of building, I'm just throwing out my ideas.
88-98 GM Full Size Forum www.GMT400.com
i put fuses on power wires, and condoms on fuses, to keep the fuses safe!
  • Who's Online   0 Members, 0 Anonymous, 1376 Guests (See full list)
