does the airspace in my port count as part of my total box volume?
or do i just subtract with mdf wood used too make the port?
my port will be slotted and falred "rounded off"
H =15 "
w =10 "
depth= 21"
now for my depth of my port...do i measure 21" from the end of the rounded edge of the port "on the outside" or the rounded end inside the port?
Edited by solosickness
Ride Stats:
2003 Ford focus Zx3 Hatch Walled System
X1 Solo X Kicker 18" "Enclosure: 7.8 cbft, Port Firing Into a Horn, On a 90*"
X1 Rockford Fosgate 40001bd "Now a Warhorse On my dresser"
x1 0g Big 3
x1 Kinetik 2400 "x4 Kinetik 2400's"
x1 Kinetik 1800
x2 Kinetik Special Edition True Silver Battery Terminals
x20 Gold Plated 0gauge 3/8 Ring Terminals
x25 Total ft: KnuKonceptz Kable 1/0 Silver Pearl* 2500+ Strands.
x15ft KnuKonceptz 8 Gauge.
-Soon Too Be Walled
Fav Quote:
They Dont Feal Me, But They Feal Me.
yes your port displaces volume therefor subtracting from total box volume
thanks alot...but now were do i start my measurement length of my port off the round edges of my port wall...
anyone who knows please?
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
your port displaces 2.73 cu ft
its a slot port tho...
so one wall doesnt count right?
so wouldnt it be...
15x10x21
and to add the mdf wood witch is 0.75
15+ 0.75
and height
10+ 1.5
right?
omfg im comfusing myself...lol
so
15.75 x 11.5 x 21 witch = 3803.625 inchs witch is 2.20117 cb ft im not sure if the solo x 18 manual is talking bout a slot port or just reg
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
it counts its the volume inside your "port" what matters
ok so what should my box = cube ft
for my box too be 10 cb ft after port displacement
thats what i need...10 cubic ft after port displacement...cuz kicker manual says there recommendations include a slotted port...with the woofer displcmnt already figured...
so all i gott do is make a box that ='s 10 cube ft after port displacment....witch is scrambling my brains....
if you can give me all my demensions i need, id be SO THANKFUL
box is already partially built..
at...
24" hight
32.5 width
and 46.5 depth witch is wayyyyyyy too much....but i know i need too shorten it, but what do i shorten my depth too to get 10 cube ft after port displacment?
consitering the port will be on the right side...and the port wall on the right will be part of the box...
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
If you feel like payin for a design and endin your headache hit me up, lol. I still say 10 cubes is WAY TOO MUCH for that sub on that power. Youre gunna kill it on 4k in that big of a box. When you run over rated power you wanna run a smaller box.
you coun't the displacement of the port as the airspace in it PLUS the extra wood used to make it. so for a slot port its Internal WxHxL PLUS board WxHxL for one piece of board.
no here as made a clear answer.
When talking about enclosure volumes its either gross volume or net volume. Total volume does not specify anything.
Net volume is the only volume of air the speaker "sees"...after all displacements
Gross is the volume of everything inside the enclosure...driver, port, bracing, etc.
