ok so i just amped up my mids and highs along with a my kenwood 6x9's. before i amped up the 6x9's they were playing off my h/u and they sounded great. now all of a sudden when i amped them up they just dont hit as hard. im running them off a alpine v power 400x4 amp.the 6x9's are rated at 80w. i noticed when i unhook one of the 6x9's just the one sounds great just as it used to. but when both of them are hooked up it sounds like crap again i figured it was the gain and filter settings but ive adjusted all of that and nothing has really changed. im stuck and dont really know whats goin on. any got any idea's???
4 sets of JL vr (discontinued) 6.5 components
4 JL wo 15"
2 JL/J2 1000.1
Alpine v power 400x4
Kenwood h/u
all in a hyundai :)
What are your outputs rated at? & have you checked your ohm loads just to make sure something wierd isnt happening? Go back through your HU and amp & double check all the settings. make sure you hooked the amp up to the right pre-outs, oh & whats the voltage at your amp on both 12+ & remote? low voltage could do this too.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
are they wired out of phase? that would be my bet, cuz what you just described is basically the textbook definition, switch the =/- on one and see what happens
if our suggestions dont help, post a pic of how they are wired, and the settings on the amp
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
might be preout voltage too low, might be the amp, might have wires switched on speakers, idk man. a 4ch 400 alpine in my head means 50 watts max xper channel @ 4 ohms. idk tho....
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
i honestly have no clue what the outputs are rated at. how would i find that out?? and as far as the settings go ive checked everything and it all looks good. and as far as the voltage goes idk. i dont have a meter :sad: . but i can tell you i have zero gage wire from the alt. to the brand new battery and i havent upgraded my grounds yet but i previously had a 1000w clas d with a 15 hooked up and that ran fine wether that matters or not.
4 JL wo 15"
2 JL/J2 1000.1
Kenwood h/u
all in a hyundai :)
well the amp is rated for 100w per channel at 4 ohms. atleast thats what it says
4 JL wo 15"
2 JL/J2 1000.1
Kenwood h/u
all in a hyundai :)
do they both seem to play fine (visually, like cone moving) when they're hooked up, just they dont sound right?)
do the other speakers sound fine?
Team DC
yeah they both are moving fine. its just when one is playing is has very nice overtones and moves through the car very nicely but when both are hooked up its just not nearly as good. and the other speakers sound fine until i crank it hard they crack a little but im pretty sure thats just my fault of a bad connection somewhere.
4 JL wo 15"
2 JL/J2 1000.1
Kenwood h/u
all in a hyundai :)
  • Who's Online   1 Member, 0 Anonymous, 1647 Guests (See full list)
