like the title says, is this a good ground?
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
under the bolt head should be clean metal (if not, clean it up) and it threads right into the floorpan which is well grounded
i vote yes
then again, if you are running some monster grounds, you may need to get more serious, but for a medium amp or two it should be fine
Edited by Lymerock
were are you gonna ground it though?..the best ground for me would be under the 2nd bolt on the bottom..sand the paint off and ground it there..thats were i grounded my amp on my TB..and also wired my mids and high amp under the seat..
if im wrong correct me guys so i could find a new ground..so far my amp has stayed nice and cool..never has gotten "HOT"
hope this helps my brotha!
Edited by DUBIE
Is that the best spot you got?
Some seat bolts have a rubber spacer or padded material under the carpet for a quieter sound in the cabin. It reduces noise. It also can make for a piss poor ground.
I was going to do the bottom bolt, but just under the bolt not the plate.
lol I keep my car pretty damn clean but that shit just comes out a on where, ya know?
and well its the easiest so far, I will check under my carpet tommorow.
I'll post my setup in my sig in a few seconds so let me know what you think
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
to make it even better. grind the paint down under the seat brace and lift and cut away some carpit gring paint of metal once all bare metal. put the lug between the floor and under of seat bracket and bolt down makeing sure all of the lug is touching bare metal.
where are you mounting the amps if the run is the same laght or sorter i would go to the strut tower enless you have a frame under the seat
but the seat bolt will do just fine.
~2006 chrysler Sebring~
~2 runs of 1/0 front to back~
~1/0 wire for "big 3"~
4 spl-hx 12'' dual 2
2 dtr 1.3400
3 c&d terminologies 1000s
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
custom dave the box guys box
new stuff on the way
Team
Soundstream
haha uhhh yeah about that, I will grind away some of the paint but im going to have to take a look at the car for more places.
the amp will most likely go on the back of the box with some rubber spacers between it
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
Try looking for a better spot first.
