cbcb900 Posted September 15, 2009 Report Posted September 15, 2009 Ok i got i have two batts. one up fount and one in the trunk. im going to wire the amps up where the middle console is. is it ok to put a distribution block between the run of the two batts and run the amps off that?
white4d96 Posted September 15, 2009 Report Posted September 15, 2009 I would just run wire from the back batt to be honest. Too many projects, too little time...
finkster Posted September 15, 2009 Report Posted September 15, 2009 your batteries should be connected to each other anyways. So you should only need to connect to one to get the power from both. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
z71kris Posted September 15, 2009 Report Posted September 15, 2009 no! Run Battery to battery to amp 03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
finkster Posted September 15, 2009 Report Posted September 15, 2009 and also, remember to fuse your power wires for the amps (of course) and jesus, fuse the positive run between the two batts.... DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
finkster Posted September 15, 2009 Report Posted September 15, 2009 I just found one that is a bit easier to read, its the same as i made above though. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
z71kris Posted September 15, 2009 Report Posted September 15, 2009 and also, remember to fuse your power wires for the amps (of course) and jesus, fuse the positive run between the two batts.... I just found one that is a bit easier to read, its the same as i made above though. yes that works better! 03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
cbcb900 Posted September 15, 2009 Author Report Posted September 15, 2009 I just found one that is a bit easier to read, its the same as i made above though. that's what i thought thanks for the help!
