kicker l7 15's
chase216
Here follow this link:
http://www.kicker.com/Product_Manuals/93/100
And look for this heading:
2004 Solo-Baric L7 Technical Manual Version 3.0 (01/01/2004)
These are the best enclosures you are going to find on the L7 and it gives you 3 boxes to choose from per size.
As for me I run tens and have always used the biggest ported enclosure they offer and for the 10 inch version I have been able to run every amp at 1 ohm load below the amps rated ohm load with out ever going into protect.
You will not find a better enclosue for daily and SPL use out there in my opinion.
Off the 2002 Termlab can you say 142 and 144 with 2 10s in a hatchback ran off a ZR360. Legal numbers.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
PS I'm probably one of the only guys to run that amp at nominal 1 ohm load for competition and did a 139 db with one L7 10.
Unfortunetly that score came from an Audio control meter and I refused a test tone and used Radio Heads song Lucky track 11 off of OK computer.
If I can't pull my numbers with music I ain't shit.
My Termlab scores were with a test tone and 2 L7 10s running the ZR360 at its manufacture 2 ohm nominal recommendation.
what kind of space we looking at? what car? what kind of power?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
no need to make two threads as well
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Trunk space? Measurements? Make sure you measure the space that you can put the box into the trunk like the openings and all that. What are ya looking for it to do? Ported? Sealed?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
slot port is what im trying but space sucks i got about 50''wide 20''deep and 16'' high.. sucks cause the closer to the bumper i get the smaller the height gets so 16 is the smallest i can go to make the box bigger
  • Who's Online   0 Members, 0 Anonymous, 2966 Guests (See full list)
