Turn the LPF down if you are getting "vocals"
Even when i turn it all the way down i still get engine noise from the subs. When i disconnect the rca's from the BR IN on the SLAVE amp the noise stops. WTF! this is really frustrating... :censored:
I dont have much free time as it is and all i want is for this ish to work..... Guess i need to be patient
'05 GMC Envoy
H/U: PIONEER AVH P4300DVD
Subs: (8) SA-12's
Amps: (2) SAZ3500d's
MECHMAN 270A Alt and 5 Batteries with lots of 1/0
only thing I can think of is that you set your gain wrong since the way you did it you set the pair of amps at 80 volts
ohms law for 6500 watts @ 1ohm = 80.6 volts
'05 GMC Envoy
Subs: (8) SA-12's
Maybe i am setting the gain wrong?...I put the + of the DMM to the Master and the - of the DMM to the Slave to measure ac voltage. If this is wrong please someone help me out.
'05 GMC Envoy
Subs: (8) SA-12's
The "fancy end" type RCAs like you have are the ones that can be problematic.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
what kind of a tone did you use to set your gain? if you used a 0db tone that could be part of it since no music is a pure sine wave
I used 50htz tone off of Bass Mekaniks 808 CD
'05 GMC Envoy
Subs: (8) SA-12's
Would you recommend a mono rca cable?
'05 GMC Envoy
Subs: (8) SA-12's
get one of the cheap RCAs from walmart and split them
I'll give that a shot...
'05 GMC Envoy
Subs: (8) SA-12's
  • Who's Online   1 Member, 0 Anonymous, 4403 Guests (See full list)
