robbie Posted September 19, 2009 Report Posted September 19, 2009 How do you hook up 2 batteries in a vehicle???
Tooshort064 Posted September 19, 2009 Report Posted September 19, 2009 Run your hot from one battery to the other and ground the other battery close to were it is mounted! make sure you sand to bare metal were ever you ground it ! 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
dmanson Posted September 19, 2009 Report Posted September 19, 2009 How do you hook up 2 batteries in a vehicle??? front battery + ........fuse .......................................fuse ...... rear battery + ......... ground rear battery to chasis in the back. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
finkster Posted September 19, 2009 Report Posted September 19, 2009 Im on my ipod touch or id type it out. Look in the electrical section there is a topic on this. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
robbie Posted September 19, 2009 Author Report Posted September 19, 2009 ok bc when i upgrade system i was going to get another battery and mount it under the hood since ive got room too....now what about altenators
