loganberry Posted September 23, 2009 Report Share Posted September 23, 2009 i tried center port in between the seats too, wasnt near as loud as the way it is now, the port fires right into my seat too, my seat is angled back and goes over the top and down below, maybe you will lose a couple tenths on the meter but there is no sound difference from the seat being all the way up or all the way back and yes its 8 cubes after all displacement Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
n8ball2013 Posted September 23, 2009 Report Share Posted September 23, 2009 subs pass side and ports driver side will help it load up in the dash pocket for a louder metering in most cases. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
zfrerichs Posted September 23, 2009 Report Share Posted September 23, 2009 Subs forward at the bottom of the box port up in the middle. Tune it to 29 hz the jls are decent sounding woofers Quote Roseville, CA Link to comment Share on other sites More sharing options...
frame dragger Posted September 23, 2009 Author Report Share Posted September 23, 2009 (edited) this was my ideasub center were the x is and as stated same flare port as mead did in the honda build redo ???????? Edited September 23, 2009 by frame dragger Quote "I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle!" -- Winston Churchill Link to comment Share on other sites More sharing options...
loganberry Posted September 23, 2009 Report Share Posted September 23, 2009 i dont get that at all^^ lol are you talking about sub behind each seat and port in the middle? Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
frame dragger Posted September 23, 2009 Author Report Share Posted September 23, 2009 (edited) Edited September 23, 2009 by frame dragger Quote "I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle!" -- Winston Churchill Link to comment Share on other sites More sharing options...
frame dragger Posted September 23, 2009 Author Report Share Posted September 23, 2009 and the port will be like steves flare port in the honda Quote "I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle!" -- Winston Churchill Link to comment Share on other sites More sharing options...
loganberry Posted September 23, 2009 Report Share Posted September 23, 2009 should work out well, ive wanted to try a port like that, ive thought about doing a ton of 12" subs and doing it that way, try it, i wanna see the outcome Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
swervinburban Posted September 23, 2009 Report Share Posted September 23, 2009 (edited) I got a extended cab with a wall thats 10^3 after displacement with 2 15's in it powered by 4k and I think 10^3 is to big for running that much power. I would recomend the 3.5-4 cubes if your going to be running some serious power on your subs. My subs are on passengerside port on drivers side. I metered a 151.6 so its possible to get loud in a extended cab. You can check out my build log if you need any tips im sure you may find something that will help out. Good luck with your build man Edited September 23, 2009 by convectedfelon Quote Under construction soon to be: 2 DD Z9518's 8 lunar L1500's (500rms each) Secondskin Dampner pro 250a Mechman rhino alt 4 runs of 2/0 (installed) 4 batteries (installed) 6-5 1/4's, 2-6 1/2's, 2-4in all ma audio (installed) Link to comment Share on other sites More sharing options...
frame dragger Posted September 23, 2009 Author Report Share Posted September 23, 2009 ok well the box size im thinking is 54 wide 20 tall 14 deep all 1.5" thick and the port will be 17" long and 3" opining 8 " deep says its going to be 35 htrz or 2" opining is 30hrtz or should i shorten the port and open it up more ?? specs please box is 5.51 cubs empty subs displace .27 for the pair Quote "I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle!" -- Winston Churchill Link to comment Share on other sites More sharing options...
