yo sean i like the amp trip panel that thing is cool and how do u got that neon under the dash.
it is a nice setup and now u got some room to put stuff in the back. now with a box tuned to 31 which do u like better the old one or new one? i want to know my box is at 36 and is loud but do u think i should tune to like 33?
holla bro
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
In my car, subs up port back sounds muuch better. And the lower tuning sounds completely different. But I like the change a lot, it's quite a bit punchier too.
And those are led's under the dash. I just mounted them up under the dash out of view, and hid the wires.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
Thats nice man, they are obviously slammin and I like that you still have a good 2/3 of your trunk. It was pumpin in the vid too!
Power Acoustik fubar 12
sony xploding amp
2 ft^3 box @ 35hz
appreciate it man. And yea this setup slumps pretty good. All I gotta do is finish up the big 3 and i can crank the amp a lil more. Right now I'm getting too bad of voltage drops.
Subwoofer Wall
Photobucket is being a bitch right now, but the install looks very nice Sean! How do you like that T1000.1BD & what kind of numbers do you think you're hittin?
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
The t10001 is amazing. The amps are barely set at 1/4 right now, and this thing puts out far more power than i need, and these subs are rated at 600 watts each. I'll be keeping the amp around for a while for sure.
As far as numbers go, I honestly have no idea. Probably low to mid 40's. If I can hit a 145 with this I'd be real stoked. But I'm going to have to find a shop to meter at.
Subwoofer Wall
hey i was going to ask u i havent seen any caps in your installs do u have any or you just running straight to the battery
holla
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
dude caps are a waste of money. Once I finish the big 3 I should be set as far as electrical goes, although I might need a lil batcap or an hc800 or something small as a secondary battery.
And as an explanation, caps only work for a short time until they discharge, after which they become a load on your system, not a buffer. Plus theyre not super effective for voltage drops. The only difference I've heard them to make is to reduce light dimming.
Subwoofer Wall
