cbcb900 Posted September 24, 2009 Report Posted September 24, 2009 i have a 1991 olds calais 2.5 i put a 200 amp alt on with big 3 using 2/0 and a back batt. can i use my old stock alt for a second one? its not a single wire alt it had a 3 pin plug on it. what would my volts go up to after having two
newls1 Posted September 24, 2009 Report Posted September 24, 2009 volts wont go up at all. The ability to hold more stable load might be better. I love my staffie So anti FACEBOOK it isn't even funny
Andrew2944r Posted September 24, 2009 Report Posted September 24, 2009 Voltage will be more steady and will drop less, look into a MLA Module if you want to increase voltage. Team Ampere Audio
cbcb900 Posted September 24, 2009 Author Report Posted September 24, 2009 well its needs to be more steady i have 1 saz 1500 at 2 ohm it dont drop below 12.3 at idle 13.3 driving. I'm going to get another 1500 so thats 2 amps at 1 ohm i dont think the volts will be able to keep up to well. i had a ma kd4000 on it went down to the 11s at idle
cqtama Posted September 24, 2009 Report Posted September 24, 2009 if your gunna run 2 different alt.s i would run the car off the stock 1 and run the system off of the big one. just an idea R.I.P '01 blazer you treated my ears well until your transmission blew up. New Project [top secret] 149.0 db on music driver window open; so close I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean.... I swear... sometimes I wish I was retarded so I could just agree with everyone x.
DroppedSdime Posted September 25, 2009 Report Posted September 25, 2009 Voltage will be more steady and will drop less, look into a MLA Module if you want to increase voltage. where can i find a place to buy a MLA Module? SPL Audio 18, 5.5cb ft tuned to 34 hzAB 150.1 @1400 rms wired to 1OhmPPI A26.5'sKenwood HU
