everfr3shh Posted September 27, 2009 Report Posted September 27, 2009 DC sound lab lvl 4 XLs or lvl 5s x2
Austin175 Posted September 27, 2009 Report Posted September 27, 2009 x2 x3 kia spectra 4 door HU-a kenwood kdc-692x optima red top under the hood ( kinetik battery or powermaster in the back ) Iraggi 260amp H/O alternator 1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming ) front speakers - back speakers - 2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future) Sundown 3500d( going to be 2 sometime ) i have boughten from - Bass14(smd), ddbump(caraudioclassifieds)
matt402 Posted September 27, 2009 Report Posted September 27, 2009 DC lvl 4xl's should do nicely. i hope there is no clippage tho...
Tooshort064 Posted September 27, 2009 Report Posted September 27, 2009 Yeah go with treo .. Not alot people know about treo and there ssx series wangs with the right power! 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
biga48197 Posted September 27, 2009 Author Report Posted September 27, 2009 then you dont have 12000 watts. more like 8000. if you are really lucky. rated at 2300 rms and more than likely doing 17-1800 Naw turn radio up on high volumes (not max tho). To find the true rms rating of a amp take a volt meter put the neg and pos on the speaker output or run speaker wire through the current clamp from the speaker output of the amp. From there you will get a read out. You take that read out and square it. Once you do that you divide that squared number by the ohm load you have your amp at. Once you divide that will give you your rms rating of that amp at that ohm load my amps have been tested with a volt/ current meter. The findings with volume on 30 (max is 35) are as follow... current output from amp was 56.2 you take that 56.2 and square it. You get 3158. Then you divide by the ohm load you have the amp at (mine was 1 ohm). So I did 3158/1=3158, which is my rms wattage at 1 ohm. Now I wont say that all PA amps can output like this one can but I have gotten good number off of different spl mics all btw 150 to 151.2 DB
biga48197 Posted September 27, 2009 Author Report Posted September 27, 2009 whats the price on the treo ssx and the dc lvl 4's and 5's
biga48197 Posted September 27, 2009 Author Report Posted September 27, 2009 DC lvl 4xl's should do nicely. i hope there is no clippage tho...I neva understood clipping how would I get it and what does it sound like, does it do serious damage to the subs?
justin smith Posted September 27, 2009 Report Posted September 27, 2009 well atleast youre charging system is up to par.... id go with either two 18'' lvl5's or four lvl4 xl's 12''s or 15''s justin smith 1996 mercury grand marquis 20'' bentchi b7 lexani n3000 245/35/20 cactus 5kw at 1ohm dcr(beast) 2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port kicker zx650.4 componets in still the works 200amp motorcraft alt xs power d3100 (beast) kenwood ddx512 h.u. you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth and BTW your girl just called me.... pure pwnage
biga48197 Posted September 27, 2009 Author Report Posted September 27, 2009 well atleast youre charging system is up to par.... id go with either two 18'' lvl5's or four lvl4 xl's 12''s or 15''s 'do u no the price on the lvl 4's 15's
