How many batts do i need?
Im starting my build in a month or so and i know i need more batts.I know i have to do the big 3 and bigger alt.My plan i a 300 amp,not sure on brand but was looking at DC Power.Thats 500 bucks.Im still trying to decide on amps.My subs will be 2 Btl 18s.My choices on amps are 1 Rf4000.1 or either 2 Sundown 3000s or 3500s.The Sundowns will be reurb from db-r.My front stage will be 1 Rf800.4 and 1 Rf400.4 on 4 sets of Hf 6.5s.Question is how many batts ,and what kind do i need.Im on a strick budget.Thanks in advance.Oh truck is 96 Chevy ext cab.
you have just named some top notch stuff you are buying bro and you say you on a budget. Anyways that RF800.4 can be ran down to 1 ohmn per channel and should run all four sets of that HF 6.5s ..... so with saying that i'd elimate that RF 400.4 (that's just me). as for amps i'd do the two sundown 3ks or 3.5k over one RF4K. batteries ......... well stinger, kinetik and powermaster will do. but looking at all the power you'd be running i'd do at minimum 3 runs of 1/0 with at minimum 3-5 good batteries in the rear. as for getting that 300 amp alt from DC, you'll definitely need it.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
im doing about the same setup and they told me about 5 d3100s would be safe. you could get by with 4 but not recommended.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
seeing he drives a chevy he might be able to do a DC300 amp alt or two. although 5+ batteries are recommended i'm sure a dual alt setup of two good alternator and 4 big batteries in the rear will do.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
that news there changes things alot.So i think 1 Rf400.1 and 1 Rf800.4.How would that work.I have right at 5000.00 for everything. 1000.00 for 2 18 Btls.1200.00 for Rf4000.1 370.00 for R800.4 240.00 for 4 sets 0f Hf 6.5s.Dc Power alt 500.00. 1 Kenetic Hc 1800 250.00. 300.00 for shop to build box. Then 400.00 for Rf 360.2.I really dont need the 360.2 but it would nice.The left over would be for misc.
with dual alts can i use a stock alt and a Dc Power?
Shouldn't be a problem I've seen a bunch of ppl run stock alts + aftermarket ones in a dual setup.
Batts wise you should be good with something like a Kinetik 1400/1800 under hood and 4 2400s in back... For those you'd be looking at like 1200-1300 for all 5 batts depending on where you get them. Call up Kinetik yourself and see if they might give u a deal for repping Team Kinetik. All depends if you have prior competing experience or if you plan on doing so next season.
Pioneer AVIC-N2
that puts me over budget im going to have to regroup this sucks
Rockford told me i only need 3 batts,1 under the hood and 2 out back,what you think
  • Who's Online   0 Members, 0 Anonymous, 1081 Guests (See full list)
