So I recently won a contest on another forum for a door pack of Damplifier Pro from Second Skin Audio, I was a little skeptical but began the build anyhow.
I also amplified the door speakers in this process and switched to some 6.5's. You will also note I used fiberglass to block off the large holes in the panels.
First off here is a picture of materials
Panel before being removed
Panel Removed, the water shield has to go
Water shield gone, gotta cover the holes
Taped up, draw an outline, apply mold release wax
Fiberglass away
Clean the panel completely with windex and rags inside and out
Fiberglass pieces removed
Deaden everything, you get 4 rectangles per front door. Stuff is really thick and heavy!
Inside picture
Zipscrew these in
Finally deaden the outer skin
I also applied a foam to the outer skin but forgot pics I will get some tommorrow, I still have another 4 sheets for the drivers door. I must say the sound difference was pretty incredible. I was skeptical not thinking it would make much of a deal but the lows are stronger and highs crispier. Haha maybe Ant will send me a trunk pack. The biggest change is the door literally feels heavier, and closes with a nice thud, cant wait to drive and hear how much the road noise cuts down!
~Mark
-Mark
Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel
Check out my forum section here on SMD for my builds and tutorial videos!
Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication
