A couple of years ago, my wife was making ( read: painting) christmasballes, to hang in the christmastree. She also hooked on making special things
When i looked at the plexy balls, i know, that sometime, i could use it for another project Well, ladies and gents, IT'S TIME
These are the plexy balls, you can buy 'm in every size. (according to his wife)..
:D:D:D
A old friend of my Earl Zausmer build 12 or 13 years ago something like this.
Posted Image
Posted Image
Then I made a hole in the bigget bal, so the little one stands a bit 'in' it
Posted Image
On this pic you can see the ball with the speaker, stands a bit further away. I did this on purpose.
Posted Image
pic with speakers in it.
Posted Image
Posted Image
__________________They will go on horizontally against the A-pillar of the car. I made already 4 copies in polyester.
Made a hole in it, and taped it all with some tape.
Then I polished it all a few times, so when he takes them apart, no polyester stays sticking on the plexy.
It also took some work to make the fiberglass so smooth with as less airbubbles as possible.
Posted Image
Posted Image
There are 2 layers of polyester now, what should be strong enough. Don't want these things to get TOO heavy.
Made another 4 alu-rings that will come in there. So it will be possible to screw the speakers tight into the alu rings.
It also popped to mind that it would be cool to cover this in CF, but that's almost not possible.
The polyester balls are ready, and look good.
On the right bal, you see a piece of polyester go loose from the plexy.
Ticked it with a hammer.
IMG]http://i82.photobucket.com/albums/j272/robola/DSC02020_resize.jpg[/img]
removed the plexy (upper)
Posted Image
Removed the lower plexy.
I made them each the same height.
First I leveled the plank. Then rubbed it in one time...
Posted Image
Posted Image
Put them together. Mesured a couple of times how much the tweeter must go backwards, and put a piece of MDF wood under it, and glued it together.
You can see I put a little filler to fill the wholes in the polyester.
Posted Image
Posted Image
I made the smaller ball crossed over in the big ball. It seemed cool...
Posted Image
Before I going further with this, I needs some alu, which my friend is going to suply. So I started making some bridles to hook them up to the A-pillars. We can assure you, a f** job which will take a while
Got some alu rings from 10mm thick to center the speakers..
Posted Image
The rings must go into the whole, and got tightened at a specific depth.
I can asure you, i was on this for HOURS.
Screwed each ring with 3 screws.
As you can see, I made the side of the ring a bit raw, and put some slots in it. I did this, so the polyester can flow nicely and everything will be fastened tight.
Posted Image
On this picture, you can see, that where the screws are, hI pasted a little piece of rubbingpaper. To keep it from moving.
Posted Image
Posted Image
In the little ring for the tweeter, I milled out a little hole. for the cables.
[Got some alu rings from 10mm thick to center the speakers..
Posted Image
Posted Image
Posted Image
Posted Image
IMG]http://i82.photobucket.com/albums/j272/robola/DSC02069_2_resize.jpg[/img]
I already kept the balls in the car, to see if they were straight, and how they would look on the dash.
Posted Image
This work seems very simple, until you do it.
To know if Left and Right are exactly the same, I took out my laser.
With that thing it's actually very easy.
You place it in the centre of the mid. I got lucky it fitted right in .
Posted Image
You turn the thing on, and aim where you want it.
Posted Image
In the background you see some trophies what i won in IASCA COMPETITION .
Include;EUROPEAN CHAMPION and BEST OF INSTAL.:
Here's how i fastened the christmasballs against the A-pillar.
As you can see, i put in a big fat roundel in the biggest ball. This was so I could hold it all firmly.
Also you can see that the hole is bigger than the screw. i did that so i can aim it.
The head of the screw I cut off a little, cause I hit the back of the speaker.
Posted Image
Upside the hole, you can see a little slot. i made that to get the cables through.
Posted Image
This is the Iron trolley who is screwed on the A-pillar.
Posted Image
This is the adapted A-Pillar.
Posted Image
So it looks in the car. The A-pillars will be covered in black alcantara.
Posted Image
Posted Image
It's tight, LOCK TIGHT !
Posted Image
Here the christmasballs of he's wifey, in the car
Posted Image
Posted Image
Posted Image
The original focal grill's
Posted Image
You may also notice that the wooden trim in the car is changed by alu...
i also made some in CF, but i didn't like it, so sold those ones, together with his wooden.
Wanted some contrast in the interior.
That's why the polyester balls will be sprayed in the silver, like the trim.
The A-Pillars are finally covered in Alcantara.
That was not so easy...
Where the hole is for the speakers, i had some alcantara to much. So pulled everything out of he sleave to make it nice and smooth.
A good thing I had big sleaves on his jumper that day .
Posted Image
Posted Image
That little shitty thing wasn't easy to cover..
Posted Image
Posted Image
Posted Image
the rest of the interior will be another 3m of alcantara...
My balls are primered
Posted Image
Posted Image
The balls are painted, and look just about perfect.
That's what I had in mind, and I made it for 100%.
Colour matches the trim perfectly....
Posted Image
Posted Image
About the little ditch in the big ball, i satisfied. Not so easy to make, and rubb it there.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
This is what you see on the outside.
Posted Image
Again something that's finished. When I thinks about it know, it has worth the effort again....
up to the next!
Cause I didn't want to change thie original 16:9 screen in the console, I had to find a place for my ALPINE CDA-7998 Phantom Face.
I wanted to do this in the middle, under the armrest. Then I had to get of the front en extend it with cables. If this was an ordinary radio, no problem, but with this radio I didn't want to take the risk.
So looked for another option to place the radio, without doing harm to the looks of the interior.
Made little trolley to fasten the radio.
Posted Image
Posted Image
Because I can only tighten this trolley with 2 screws, I made it extra strong. all made of iron.
The radio won't move a mini-mm, it's locked TIGHT !
I also weld the original sleigh of the radio onto it.
Posted Image
Posted Image
Posted Image
The fiberglass piece I made for the radio, is finished.
I lost about a day on this piece to get this perfect. When u sit down and
look closely, it was a bit slanting.
reason: the dashboard of the beemer was slanting also: conclusion:
THEY WERE ALL MADE ON MONDAYS
So I placedit, so the lines in the dashboard flow with the piece for the radio.
Posted Image
Posted Image
Posted Image
This will be the new place for the radio.
There was a little meaninglesscompartiment here for some useless stuff, so lets give the space some meaning !
Not the normal place for a radio, but that's was just so we didn't have to **up the middleconsole...
There will be people who don't like the setup over there... but didn't have an other (GOOD) option.
In the iron...
Posted Image
This is the result of the fiberglass piece.
Thougt of covering it in CF, or doing it in matt black, but changed his mind on the last minute and sprayed it silver? like the christmas-speaker-balls.
Posted Image
Posted Image
We were afraid it may be a bit too much silver, but cause the piece is really far down
If he changes my mind about the colour, it can be resprayed in black orso.
This is the radio with the screen clapped in. .
Posted Image
Posted Image
Posted Image
This is the sight when I sits in the car. Just enough the see all of the radio.
Posted Image
Posted Image
Posted Image
Posted Image
I have just noticed you are alot further ahead on this build than you have posted here, what stage are you at now... the amp rack, is that the most current part of your build...
oh and absoultly amazing work... I think you have inspired alot of people to put in a bit extra to all thier installs
The advantage of posting on forums is that you can sometimes take idea's from the people who reply...
got the armrest between the seats and screwed it onto a wooden plate.
So it look originally
Posted Image
Posted Image
This is the original remote controle that came with the radio.
Posted Image
Took it apart. First thing I did is take the eye (aiming to the radio) out of the remotecontrol (out of the printplate), and I will place it under the seat.
problem solved.
Posted Image
the meaning is the remote will glide out of the armrest.
This is the -so called- glider where it will run into
Posted Image
you can see, I did a disc-job into the armrest
Where the thing stopped, it'll get the same shape as the upperside.
Posted Image
Posted Image
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
