i've decided to use a motor .
Posted Image
Posted Image
Posted Image
Posted Image
The frame to mount the cross over tray also needed some extra attention to make it stronger.
Now, finally, everthing works as planned.
So now it is time to complete the next step: make the covers for all this...
As you can see, i've made a decent hinge.
The alloy plates that were supposed to mount on the sides of the tray ended up with the trash.
The ones you see on this pictures still need to be polished
Posted Image
Than i used a big piece of glass to create a large piece of carbon. Clearly it still needs some layers of varnish.
Posted Image
These have been cut into several pieces.
These parts will be mounted on the inside of the tray (visible when opened)
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Afterward i made a cover for the bottom of the trunk.
A hell of a job.
Posted Image
The beautifull curves a not visible on the picture.
Posted Image
This piece is mounted using 5 screws, still 3 visible (for now...)
Posted Image
Posted Image
Posted Image
This is the front view, for this i still have a cool trick up my sleeve, but more details lateron.
Posted Image
Here it shows that my side pieces are too long, but i did that on purpose.
It als shows that the bottom needs some filling so that everything become nice and smooth.
Posted Image
On this pic i show you were i've stopped with the curver. the staight mdf piece will eventually become round. i really hate straight lines!
Posted Image
Nice Work!!!!!!! Amazing skillz you have!! :yahoo:
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
lovely build man... This build was linked to SMD a year or so ago, I loved it back then, and its still lookin very nice
Thanks dude, I do my best… and sometimes it looks I had it in my mind. :db::db:
These 2 holes will be used to guide the speakerwires. I've made them big enough so that it doesn't create friction when the entire things moves up and down.
Posted Image
Posted Image
Posted Image
In the meanwhile i've reinforced the suspension of the cross over tray and spray painted it black
Posted Image
Posted Image
I've also modified the tray itself. As you can see, the alloy and plexi parts are no longer going all the way down.
Posted Image
Posted Image
I've also modified the curver here and there.
Posted Image
Posted Image
Posted Image
I created some nice curves on the side pannels so that they nicely fit te curver.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
I've mounted a alloy bracket left and right xich will be used to hold the curver.
Posted Image
This is the minimum margin.
Posted Image
Posted Image
When opened, you see the small carbon border. I thing this is the nicest look.
Posted Image
Posted Image
Overall picture
Posted Image
The front piece of this set up will be mounted seperately. This will be a huge task!
  • Who's Online   0 Members, 0 Anonymous, 827 Guests (See full list)
