So guys my Taurus has went through many a system but is time to let loose and get it to the point I have always wanted. Crisp clean highs and solid bottom end, by no means "sq" perfect but close as I can still being loud.
Plans include:
AQ2200D Amplifier
Fi BTL 15" Loaded D2
2 Batteries
Upgraded Alt
1/0 Gauge Runs and Big 3 (Complete)
Fully Deadened Front doors (Complete)
Trunk Deadened
4 Cubic Foot Box at 34 Hz with Kerfs (In progress)
Pioneer Door Speakers and 12 Gauge Ran through molexes (Complete)
Amped Front Speakers off Profile AP400 (Complete)
Some pics of the big 3
Started the box:
Here is a sketchup model of it, the front will be double baffled, hence the offset you will see inthe build pics, so far there is only the back section
Practice kerfing
THis is the inner port section
Port painted
Thats it for now, I love input, let me know what you guys think, I learned a lot about kerfing, so any questions ask... :)
-Mark
Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel
Check out my forum section here on SMD for my builds and tutorial videos!
Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication
dude this is crazy because this is the exact same setup i wanna run
i already gotthe 2200 d
i juss need the btl, wiring, alt, and batts lol
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
Thanks guys, I already got a pm with questions about the kerf here is a quick response, on my next one I will take more pics
"In a basic explanation you run a circular saw in parallel lines that nearly cut all the way through the mdf but leave about 1/16-1/8 an inch. To get a 3 inch radius I did 11 cuts at 1/2 inch intervals,for 6 inch just do 11 at 1 inch. When you go to bend the wood you slowly work it back and forth in order to avoid it snapping. Then clamp it in place (you dont have to do 90 degree angles) and fiberglass it together, it went pretty smoothly, just make sure your lines are real straight, a table saw with fence would be optimum but I got away with just using a jig I made with my circular saw"
-Mark
  • 4 months later...
