can anyone tell me how to set the gain on my amplifier i heard there was some equation you can work out and use a multimeter can some one break this down and explain it for me
2000 toyota tacoma ext. cab
JVC AH-59 head unit
knukonceptz 4ga kolossus Amp kit
hifonics brutus 1200D
2 Kicker CVR 12
prefab vented enclosure
take the rms on your subs, multiply it by the ohm load your runnign to the amp and then find the square root of that and that number will be your target voltage which is what you want on your multimeter
Not positive but I'm guessing that there is a gain setting tutorial somewhere on here you could read.
Pioneer AVIC-N2
This is how you do it. Example: 500rms(total) X 2 Ohm = 1000 take Square root of 1000 = 31.6 Volts
Its very simple once you learn it and use it often
Honda Accord 4 Door
Current System -
(2) 12'' Mtx Thunder 5500's
(1) Alpine Mrp-m1000 @4Ω
(1) Pioneer Deck Deh-3500
(1) American Legacy 1.0 Farad Capacitor
(1) Stinger Voltage Meter (Blue)
Big 3 Knu 1/0
Box 3.4^3@37hz
  • Who's Online   0 Members, 0 Anonymous, 1092 Guests (See full list)
