Ported or not?
JV0493
What exactly are the advantages and disadvantages of a ported box? My dad was into SQL back in the day and said no one ever ported their boxes. Does a ported box hurt SQ?
Ive been doin ported boxes in my car for a while with one sealed box inbetween somewhere, I put a sealed box in my gfs car due to space a little while ago, and im about to switch back to sealed for a while because that sealed boxes hits notes all around, my ported boxed usually do good from ~20 to ~45 or 50. I think mine have been peaking to low, and not playin higher notes, but when i tune higher i cant get the lows at all. so with to lower rolloff of a sealed box im goin back to it for a while, The sealed box i had was also the only box to have my faceplate pop off the radio,
I want my bass to sound clean and clear not just rattle the crap out of my car.
If you want clean, pure bass that doesn't need to cause an earthquake take a look at the Autotuba
http://www.billfitzmaurice.com/AutoTuba.html
It get amazingly loud off of almost no power, not to mention it is cheap, and has better SQ than any direct radiator configuration.
Its a bit more complicated than a regular vented enclosure but its well worth it.
just a horn box.
  • 1 month later...
How the hell are you going to get good SQ out of plywood???????
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
The difference is the more air you move the more sound waves you produce. But the hard part about a ported box is tuning it correctly with the least amount of sound waves getting canceled out that's where SQ comes into play. The least amount of waves canceled out produces a clearer sound that is louder without "muddying" up.
so more air moved = more soundwaves? so a sealed 18 has more soundwaves than a sealed 12? I think not. More air moved means more presssure. A ported box helps allign the front and back waves of the driver to gain more output. It effects the amplitude of the wave, doesnt make more waves. Feel free to correct me if im wrong here.
  • Who's Online   0 Members, 0 Anonymous, 1794 Guests (See full list)
