Would I need b and c pillars? My box is below the window line and I was wondering if I can do ss nw? I know Doug told me I need a headliner door panels a pillars and carpet I didn't ask about the other pillars
For street c what is the battery limitation? And what is the woofer limitation?
And the box had to be below the window line in the street classes?
Roseville, CA
Street C you're allowed one battery under the hood and one battery in the back. I don't know the battery size limitation. Everything must be below the window line and in the cargo area. Vehicle must remain totally stock. For subs you can run up to 6 10s, 4 12s, 2 15s, or 1 18. I believe you can run up to 4 amplifiers but not 100% on that.
SS no-wall you can do whatever you want as long as it's behind the b-pillar and below the window line. Vehicle must remain stock in front the b-pillar and above the window line.
Kewl! Thanks
anybody know the batt size for street c?
i want to run 16v
anyone know of a bigger 16v batt?
other than the kinetik and powermaster
Roseville, CA
For Street C you can have 2 amps or 2 pairs of strapped amps I believe... Batt limitation - 2 standard 800^3
Off Termpro -
Street C Class - A maximum of 2 subwoofer amplifiers (or 4 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 4 electrical conductors may be used to connect the amplifier(s) to the woofer(s).
One 18-inch woofer
OR a maximum of two 15-inch woofers
OR a maximum of four 12-inch woofers
OR a maximum of six 10-inch woofers
OR a maximum of eight 8-inch woofers
Btw you can't run 16v in street C, but you can in SS NW.
Edited by Marlo Stanfield
Pioneer AVIC-N2
Kewl! Thanks
i want to run 16v
Definitely you will be on SS NW if you planned of running 16 volts batts . . . . :clapping::clapping::clapping:
TEAM S.S.C.
Team Serious SPL Centurions
All of this depends on what will fit in the car.. Lmao
Regardless what kind and size of battery that will fit in your car, as long as 16 volt batt . . . . you will be on SS NW.
That if, your thinking between SS NW and Street C class.
TEAM S.S.C.
Good to know i think ill stay away from 16v in this project
wouldnt really be worth it
id like to be in on the burp fun next season
Roseville, CA
  • Who's Online   0 Members, 0 Anonymous, 5467 Guests (See full list)
