Orion HCCA Box
barros57
Any of those crazy good box building people out there? this is the 1st ive actually built and tried to tune. Thanks guys
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
Can anyone help me with a box design tuned to 37 HZ? The availiable area is 16 in wide, 18 in high, and 36 in long.
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
SPECIFICATIONS
Directed Part Number 27302
Model Number 10.2
Thiele/Small Parameters
Fs (free-air resonance, Hz) 30.78
Vas (equivalent compliance, cu. ft. 0.564
Vas (equivalent compliance, liters) 15.98
Qms (Q, mechanical) 3.63
Qes (Q, electrical) 0.42
Qts (total driver Q) 0.38
Re (DC resistance, ohms) 3.93
Z (nominal impedance, ohms) 2 x 2
Le (inductance, mh) 1.93
Efficiency (1W @ 1M, dB) 83
Xmax (one way linear excursion, in.) 1.0
Xmax (one way linear excursion, mm) 25
Pe (continuous power handling, watts) 1500
Peak power handling (music, watts)** 3000
Mms (total moving mass, grams) 261.93
Cms (mechanical compliance, mm/N) 0.102
Bl (motor strength, Tesla-M) 21.81
Sd (effective radiating area, sq. cm.) 333.3
Sd (effective radiating area, sq. m.) 0.03333
Sd (effective radiating area, sq. in.) 51.6616
Frequency range (Hz) 31-250
Energy Bandwidth Product (EBP) 74
Driver Physical Dimension
Speaker Displacement (cu ft.) 0.1268
Mounting hole diameter (mm) 238
Mounting hole diameter (inches) 9.37
Mounting depth (mm) 214
Mounting depth (inches) 8.425
Magnet Weight (Oz) 263.7
Basket diameter (inches)
Recommended Enclosures
Typical sealed enclosure (cu. ft.) 0.5 to 0.8
Vented enclosure (cu. ft.) 1.2
Port tuning frequency (Hz) 38
Port diameter (inside, in.) 3.4
Equivalent square port (in.) 3x3
Port length (in.) 12
Enclosure Details
1. Parameters listed are for conventional applications only, for further help please call Tech Audio Support
2. 1" MDF is recommended.
3. Recommended enclosures are NET Box Volumes, speaker and port displacement are calculated into the
volume of the enclosure, you will not need to add these volumes to calculate GROSS volume for the
enclosure.
*** Sub-sonic filters should always be used and adjusted specifically for vented box designs.
NOTE: The woofer must face up or down only, especially in sealed enclosures.
Specifications subject to change without notice
© 2007 Directed Electronics, Inc. Vista, CA 92081 All rights reserved.
24
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
anyone :(
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
  • 3 years later...
Thanks,
Its annoying that sonic has the recones for the 12's and 15's, but they discontinued the 10"
grrr
well they do sell the recone kits for the 10.2 & 10.4 hcca orions on amazon. I am not sure how long they will be having them up there for or what the quantities on them are. but they do have them.
Thanks,
grrr
Man, welcome to SMD, it's good habit to take a look at the post date of the comment you are replying to :)
  • Who's Online   0 Members, 0 Anonymous, 771 Guests (See full list)
