I have a question on why, when i play my music above 44 volume it start's to skip or cut out. I have tried even a new cd and still the same problem.
jrplayer36
Do you have a sub? Maybe the sub is causing the cd to skip.
Going into my new setup in the 03 PT Cruiser:
15" Adire Audio Brahma Mkii
AQ 1200D
Alpine 9884
3.5 cubes tuned to 29hz with square port(thanks Ben Building!)
ILLusive Theory(ILLSET)
Dreams Clothing!!
I have 2 12in subs. If that is the case time for a ipod
jrplayer36
are you talking about clipping? or is the music skipping? cuz if its clipping that means ur giving either ur speakers or subs too much power...
2005 Dodge Magnum
Kenwood DNX573S Double Din
NVX Big 3 Kit
NVX 0 Gauge Cable & speaker cable
XS Power V3100 Battery
Iraggi Alternator 320A
3.5" NVX Speakers
6.5" Incriminator Audio Components (just mids)
6x9" NVX Speaker
MVPA4 Amplifier
(2) 12" NVX VCW Subwoofers
XPLD3K NVX Amplifier
YouTube Channel
@CarlosTj664
or ur subs are taking too much power from the amp and when u get to a certain volume u cant raise the volume cause it starts to clip and its because its not enough power for your subs and it doesnt kick and skips some bass lines...
2005 Dodge Magnum
NVX Big 3 Kit
3.5" NVX Speakers
6x9" NVX Speaker
MVPA4 Amplifier
YouTube Channel
@CarlosTj664
I'am running a MB QUART DSC 1000.1 amp to my RE SE Subs, it actually stops playing music and plays and stop for a few sec.
jrplayer36
Check your grounds, mine used to do the same thing with my Kicker Zx.1500, changed to a better sanded ground and the problem was fixed.
¿ǝɯɐƃ ǝɥʇ
Could be a grounding problem, HU skipping, clipping or amp going into protect for a number of reasons.
Pioneer AVIC-N2
I will have to look into it, take it back to were i had it installed.
jrplayer36
  • Who's Online   1 Member, 0 Anonymous, 1283 Guests (See full list)
