ok, so this is going into a dodge stealth hatch, so that is why it looks so retarded. its an enclosure for a Fi BL 15....
im looking for around at least 3 cubes after displacement....I have a couple of questions.....i wanna port either drivers side or the rear...but i only have about 4 inches from the back of the box to the hatch....so i dunno if that would starve the port or not...but can u guys help me design a port? i can run either aeros or slot port back....
OH AND THE BOX WILL BE 10.5 INCHES DEEP.....
this is a birds eye view of the box.
Edited by finkster
Eclipse cd7000
Can the sub be moved farther towards the rear of the car, then you could move the port forward till you got a little more than the 4in clearence?
93 Chevy Silverado
Crossfire,Dayton
Soon to have 6 Lvl4 15s
DC Audio Dealer and Team Member
i got 4.475cuft before port and sub displ
if u use 1 6" aero and bring that box volume down to 4cuft the port would need to be 14" deep to be tuned to 32.14hz
supposedly since the aeros have the flare u can put them 3" from a inner panel so im guessing 4" will be fine outside the box... if not u can add more clearance because u dont need the box to be as big as u have sketched out, so u can shrink the overall depth
thats my suggestion
depends on alot of things, do u want 1 6" aero or 2-3 4" aeros and since u know now u can go up to 4.475cuft what do u want ur final volume to be
Edited by Decaf
id rather have one six but 2 4s dont bother me much.....
should i port back left side?
Eclipse cd7000
well then u could do 2 4" aeros firing up and use pvc elbows...
put the aeros in the rear corners and angle the inside port flares towards the sub
is there enough clearance to do ports firing up?
if not then just do 2 4" on each side firing back
or if 1 6" aeros just stick it in the middle and move the sub as far forward as you can
stealths suck, lol... why arent u doing 2 10s anymore?
Edited by Decaf
im actually trying to avoid ports up...it wont work, the hatch is in the way
cant i just do 1 6 inch firing out the left side?
Eclipse cd7000
and also how long should the 6 incher be? no homo
Eclipse cd7000
anywhere from 32-35...whichever is best for the bl
thanks decaf u da shit mane :D
Edited by finkster
Eclipse cd7000
if ur using the sketchup above
4.4cuft i included .1cuft for bracing... so just use small 45s and dowel rods and ull stay around 4.4@32
13" total length including flare will give u 32hz
10" total length including flare will give you 36hz
hatches sometimes dont get as low since the cabin space is smaller so id stick closer to 32hz than 35hz imo
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
