Hey guy's it didn't really bother me at first but now im kinda irritated and starting to get mad, The problem is one of my subs isn't moving as much as my other one.
I switched around the signal cables and still the right one is moving more. The left one is closer to the port so IDK if that is the problem or what.
Have any of you guy's ever have this problem?
(It's the sub on the left obviously, the one closer to the port)
2 Infinity Reference 1252w 12s
4.2 cubic foot box tuned to 28hz
Sub amp: 1 Profile AP1200
Speaker amp: 1 Sony Xplod XM-504z
Kenwood eXcelon KDC-X492
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
f05112e8-c6ca-4f78-9a8d-47be99303c8b_zps
Diamonds are forever, but 9's end that shit fast....
maybe the sub not moving as much got disconnected and it just moving from the pressure of the other
does the box have a L port
and can u hook up each sub by itself to test each?
Edited by Decaf
It's has a little bit of a signal because if I put presure on it with my finger I can feel it lol.
Yes its a L port
I'm gonna go try each channel alone.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
i used to have these subs, and the lead wires used to come off sometimes. i would check that.
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
Yes its a L port
You will still be able to feel it moving if the right one is going because they are sharing airspace and the pressure will move the cone on the left one. Check your wires, and if everything is hooked up right, you are probably experiencing loading issues(right sub has an easier time moving creating pressure and making it harder for the left sub to move) I've never been a fan of multi sub single port enclosures for specifically that reason.......
CAUTION!
POOR INSTALLATION MAY SHORT BOTH YOUR SYSTEM AND WALLET
Thank you Decaf. I made a noob mistake and didn't check by unpluging one of the channels and I had no bass! So my wire came undone in the box.
Thanks again bro.
and thanks ugpbmx
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
Yup thats was the prob. I should figured that but I didn't.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
Thanks again bro.
and thanks ugpbmx
no prob, sounded like a simple fix
I've had this problem and it was my jumper wire loose that was going from one coil to the other on my sub.
precisely
ur welcome :friends:
should be louder now too since u will lower the impedance hookin up another coil
Edited by Decaf
  • Who's Online   0 Members, 0 Anonymous, 2418 Guests (See full list)
