Okay I have 2 Btl 18's. 200 amp iraggi alt, and big 3. Now the question I got 3 hifonics 1200 watt amps super cheap I was just going to buy 1 more online and run one amp per coil they are the d2 fully loaded now would this work ok or is it stupid?
Edited by steven
the sub is a dual coil bro
that will not work
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
should work, u can buy a max link n run ur signal into it n then out to the sub amps n they will all be tuned the same, so i see nothing wrong with it, but i wouldn't try it without maxlink cause it can run pos n neg outputs from it so im not that sure on it
but 4 amps on 2 subs should work, what kinda batterys n how many u got?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
I dont see a problem with running amps to 2 subs, as long as you can match them all together perfectly
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Yes that will work with a maxx link,,, but you will only be giving each sub around 1400-1600 rms... I can't remeber if you can strap those...
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
I have 1 optima yellow top under the hood and 3 hc 1800. I was looking a maxxlink but you really think I need 1 I thought I could just set them all exactly the same as far as gain, l/p, ect.
that will not work
u can run 1 amp per coil, thats wut steve is doin in the hoe when his new woofers are comeing, so i say it should work daily also, ive ran a 2ch amp to a dvc woofer n it work fine so i see no harm in doing it
heres what i mean with a maxlink
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=20093
its alot easyer useing a maxxlink than tryin to do it the old faction way with a dmm checkin voltage, just hookd rcas in, set to slave i think n then on u go
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
hope this helps
1400-1600 rms??? Each amp is 1200. I know hifonics amps are over rated but I think it will be a bit higher than 1400 per sub.
  • Who's Online   0 Members, 0 Anonymous, 3033 Guests (See full list)
