My first thought was tinsel slap or that it's just bottoming out.
Pioneer AVIC-N2
its not bottoming out. i think its the voice coil
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
Theres no such thing as tinsel slap on the AQ's or DD's.
More than likely its the spider shifted slightly around the cone/former joint and has created a mild coil rub. Had this happen several times with my AQ's.
Sub will still play hard. It's just a nasty noise that eventually will kill the sub.
This is a severe rub
Both of those subs ripped the spiders away from the cone
thats pretty much it... it also got worse as i played it more at a loud volume... is there anyway to fix this or recone time?
Big 3.
Kicker ZX200.4
sounds like recone time... once the soft parts defect its pretty much over...
ok so here is the deal...
option A: If its not under warranty... get your video camera out and hook it up to a light socket... make sure to get a good quality vid for us! and then get your recone...
Option B: if it is under warranty... get your free recone... and then see option A...=)
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Is your gain set properly? because you could be botteming out, and what your hearing is the sub hitting itself.
Really hard to do on the AQ's without a ton of power.
Mine did this too.
Pull it from the box and take a look at the spiders.
I found out that the top spiders had torn all the way around and from peak to peak it would pop over to one side or the other.
