I run my AB VFL 400.1 @ .5ohm daily with no issues at all... Basically as long as your electrical can handle it and the amp can also then you shouldn't have any issues @ 1ohm.
Pioneer AVIC-N2
electrical system is as follows
big 3 1/0 gauge (once I get home for a min from work so I can get some numbers to scottj before he runs out)
1/0 gauge power and grounds (knu concepts wire installed now )
150 amp alt
xs power battery in rear ( soon before or at same time as 1 ohm conversion)
if you keep enough power to it, it will be fine
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
what does your electrical system look like? your going to need a SOLID 14.4volts to get rated power out of the brutus... decent amp though...
I can get 14.4 now that i dumped the stupid cap I had in stalled that reduced my volts to 12.8 max, with out the xs battery ( I plan on gettin) I have 14 + at the rear
