I need a new sub amp and am thinking of running my JL's at 1 ohm. question is will an amp at 1 ohm load get to hot for a daily driver ? the amps arent hidden so air flow isnt an issue and I can add fans, just wonderin if I can run the amp for long peiord of time or not
not at all. as long as they're one ohm stable, and if you can provide enough juice for the current draw. tons of people run them at 1 ohm. some people run select amps at lower impedances than that :) what amp did you have in mind?
Yea just get a 1ohm stable amp, easy as pie. shouldnt have a problem with overheating unless its not meant to run at 1ohm.
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
exactly whut they said. ive been running mine for 9 months straight everyday poundage baby
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
thinking about the
bxi 1210d hifonics (I have a brutus 5 channel now for mids and highs and like it ) here are the specs
Brutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
RMS Power Rating:
4 ohms: 450 watts x 1 chan.
2 ohms: 900 watts x 1 chan.
1 ohm: 1200 watts x 1 chan
what does your electrical system look like? your going to need a SOLID 14.4volts to get rated power out of the brutus... decent amp though...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
that amp will be fine at 1 ohm. but i agree with rogers, it'll need a stout electrical to get around rated power from it. but with only up to 1200 watts on tap, your current draw wont be too much, so your upgrades wont be too drastic, if any at all since we dont know what you have right now
yeah, I run mines at 1 ohm for every day stuff..
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
