FS: Massive Audio CA-100 -- $150 Shipped FIRM
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
520w x 2 RMS / 1040w Max., high current amplifier, bridgeable. 18db bass boost @ 45 Hz. Continuously variable 18db X-over with phase shift/time alignment control. Balanced line inputs. Surface mount technology (SMT). Mil-spec. double-sided gold plated Circuit Board. Regulated dual power supplies using PWM switching. MOSFET transistors used in both input and output stages. On board computerized protection monitor. 1 ohm stereo, 2 ohm mono.
Weight 14.00 Pounds
RMS Power 520 x 2
PEAK Power 2080 x 1
RMS@2Ohms 330 x 2
Bridged RMS 1040 x 1
Min Impedance 1 Ohm
Min Impedance Bridged 2 Ohm
THD 0.005
S/N 112 dB
Max Voltage 16v
Max RCA Voltage 4.5v - 18v
Freq. Responce 5Hz - 50Khz
Dimensions 9.75" x 2.5" x 11.5"
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Class a/b?
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
This topic is now closed to further replies.
