Whats should i be aiming for if i want a crazy low end. ie i want to play 25-33hz as loud as possible but still play music up to 40hz.
Other than just tuning uber low what else should i be doing? BIG box? what kind of woofers is a low fs and big xmax important?
Maybe a Tline if you want. Forevrbumpn has a tutorial on how to do Tlines stickied in the Subwoofers/Enclosures section.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
A low FS and a lot of stroke is a good thing to have when you are looking for insane lows but the right enclosure plays a huge roll also. I personally have build some boxes that smash the lows but are extremely lacking after 40Hz with a huge roll off but in the end I always end up rebuilding to something that has a flatter response curve. It may be cool for a while, but daily it gets old and you want something a little more "full". Several different types enclosure will do what you want, t-lines, 4th or 6th order BP or a standard ported enclosure will do just fine. For a standard ported enclosure, I would suggest a large low tuned enclosure with a good amount of port area (16in^2 per ft^3).
  • Who's Online   0 Members, 0 Anonymous, 957 Guests (See full list)
