I'm doing the big 3 today and my stock alt wiring goes into my fuse box but it doesn't look like it hits a fuse. can anyone help ? can i go straight from the alt to + term?
Fusebox
Honda Accord 4 Door
Current System -
(2) 12'' Mtx Thunder 5500's
(1) Alpine Mrp-m1000 @4Ω
(1) Pioneer Deck Deh-3500
(1) American Legacy 1.0 Farad Capacitor
(1) Stinger Voltage Meter (Blue)
Big 3 Knu 1/0
Box 3.4^3@37hz
that is the fuse circled
and leave that alone along with all of your stock wiring....u are simply adding wiring and fuses..not replacing the factory wiring
i likes me some audio stuff...
So how do i do the big 3 in my car? i just bought like 50$ worth of wiring. for the big 3 all you do is upgrade the wires right?
Honda Accord 4 Door
Current System -
Big 3 Knu 1/0
Box 3.4^3@37hz
leave the stock wiring....u are simply adding wire
add a positive run from the battery to the alt...fused
add a ground run from the battery to the engine block (i attached it to the bolt holding my alt in)
add a ground from your battery to the frame
Edited by andym85
Does it HAVE to be fused? and what kind of fuse? 150a?
Honda Accord 4 Door
Current System -
Big 3 Knu 1/0
Box 3.4^3@37hz
Its just more safe doesn't have to but its better to. I think I used 240 or so.
Edited by Ghost06GT
Head Unit. Jensen Flip out
Subs. 2 JL audio w6v2 12's
Sub Amp. JL Audio 1000.1v2
Rear and door speakers. Eclipse 6.5's and 6.9's
JL tweeters
Mids&Highs Amp. Planet Audio 400.4
Big 3 upgrade all in Kolossus Fleks Kable 1/0
i would highly recommned a fuse....just because its safer
u fuse based on the size of wire....for 1/0 gauge the biggest u can go is 325 amps....150 will probably work...if it were me i would use something bigger....like 250amps+
So its all good not to have a fuse in, when i have money ill get one and install it. Thanks for help!!
Edited by Demo402
Honda Accord 4 Door
Current System -
Big 3 Knu 1/0
Box 3.4^3@37hz
Going to get a 250a fuse tomorrow
Honda Accord 4 Door
Current System -
Big 3 Knu 1/0
Box 3.4^3@37hz
  • Who's Online   0 Members, 0 Anonymous, 3237 Guests (See full list)
